  New Posts New Posts RSS Feed - 1985
1985
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Topic: 1985
    Posted: March-06-2018 at 5:12am
Ski pylon previous owner cut the ring off to install wake board pole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: March-06-2018 at 9:34am
Clown
Wil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2018 at 5:27pm
There is one on ebay
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2018 at 5:45pm
Pylon with a ring and finger? How about a link?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2018 at 5:55pm
I have a pylon and am less than 90 minutes from Lake Norman. Not perfect but has the ring and finger attached.
Donald78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald78 Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2018 at 7:03pm
I have a pylon chrome off of 86 ski nautiquie 2001
LDH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LDH Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2018 at 10:35pm
I am interested in getting this. I need it for my boat. How can I get in contact with you?
LDH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LDH Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2018 at 10:36pm
I am interested in this. I need it for my boat. How can I get in contact with you? This is for Red.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald78 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2018 at 3:48pm
I am sorry it to so long to get back did you a ply on thanks Donald 78 419 788 0523
LDH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LDH Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2018 at 4:28pm
I have not found one yet but I want it......
repifanio2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote repifanio2 Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2018 at 8:33pm
How do you take the ring off the pylon?
RKE
Wil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2018 at 6:50pm
should be allen set screws to remove
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2018 at 7:06pm
No.
Roll pins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2018 at 7:10pm
No.
Roll pins.
Ralph,
You'll see a hole below the ring/finger where there's a spring pin. Some call them a roll pin. It's what's holding the ring/finger in the pylon and it needs to be driven out. Then the shank can be really stuck due to corrosion. Some have resorted to applying upwards force with a chain hoist or "come a long" while twisting the ring back and forth. Be carefull not to apply too much force on the ring since some have bent them.
Lynn,
What kind of boat do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote repifanio2 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2018 at 12:37pm
86 2001 I got one pin our but probably bent the other
RKE
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2018 at 1:01pm
Ralph,
Pin punch
Pin punches are sized to be slightly smaller than the pin you are removing. If you use too small a punch, you can "mushroom" the pin end and locking it in the hole. Did you use the proper size? My suggestion now is to remove the pylon and get it into an arbor press to see if the pin will come out. You may have to resort to drilling it out but that can be tricky since the pin is hard. A carbide drill in a drill press would be needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote repifanio2 Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2018 at 3:43pm
thanks for your help
RKE
