  New Posts New Posts RSS Feed - 1985 2001 with 454 - dead
 Post Reply Post Reply Page    <1 34567>
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 1:18am
How did they start this new engine? Your old starter could not work?
My guess is they knew full well what they did because they had to swap starters before it ran.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 8:08am
Originally posted by Ian Ian wrote:
and he says that Ian's gonna have a day of much discussion with the dealer about leaving that engine in the boat, we'll give you a discount, we'll buy you a new prop etc
And some posting here for opinions
Shop just called. They said that the talked to the engine supplier, and there was some miscommunication and that reverse rotation engines are becoming phased out and less popular, so they are more expensive and harder to get...
Ian,
Was it ever confirmed who made the "miscommunication"?
I'm sorry to hear they talked you into the LH solution.
What was the incentive they made for you to make what I feel was the wrong decision?
However, I'm happy to hear that at least one person at Tommy's knew that the trans could be indexed. I wonder if any of their "techs" have ever done an indexing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 8:48am
Yes, the plot thickens!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 8:56am
Originally posted by JoeinNY JoeinNY wrote:
If it was a super original boat having a LH engine instead of the RH engine cuts the value in half IMHO. Having a LH engine with a LH prop in even a modified boat means someone was willing to cut corners to save money. Either way not what you wanted which was a nice boat with a rebuilt engine installed at a marina which would have been a positive over an original engine. The 1:23:1 transmission option wouldn't be terrible, but its a new trans, new shaft and a new prop which is a quick 2500 (maybe 17 to a dealership) so reasonably unlikely they will go for it - I would probably offer it to them though.    If you are not selling anytime soon value is not really important but having had both a LH and RH 2001 I can tell you I much prefer it RH as I no longer feel the need to drive from the passengers seat on a regular occasion.
Hopefully this advice was absorbed before making your decision, it is pretty much spot on. The only thing I’ll clarify (and I’m sure joe would agree) is that the 1.23 trans (which would mate your LH engine to a RH prop) would be a terrific option from a performance and reliability perspective... only downside is the cost. You can put me squarely in the camp against using a LH prop, I’ve owned one and driven many, they handle poorly IMHO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 9:58am
After much research, including calling Correct Craft directly, and engine manufacturers, as well as people who have run similar boats with both OEM and non OEM opposite rotation engines in the same boats, I have elected to convert to LH..
Your not saved by their error yet if you go against what was originally in that boat. Doubtful that anyone a consumer could contact at Correct Craft would even have any knowlege of a boat using a right hand engine. A BFN is alot different boat than a flat bottom Nautique. Art Cozier would be the guy to ask. You might also contact Jody at Florida Inboards,run it past him and see what he thinks. In the end it's your boat not mine,you need to do whats right for you.
Ian,
I agree with Gary. Who called CC? Tommy's? What LH prop are they going to give you?
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 10:19am
I ordered a starter with the engine, The old starter needed to be replaced.
Yes they knew full well that they were installing a LH engine the whole time, they were under the impression that that is what I wanted - although I don't know how since I gave them the right part numbers
'85 2001 454
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 10:20am
That is the easiest solution for Tommy's to deal with. Hopefully, you'll be happy with the way it drives. It'll give you a story to tell every time someone admires your boat and asks why you converted it to a lefty.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 10:35am
Ian,
I really don't know where the miscommunication happened. When I discovered the problem the shop seemed to believe that I requested a LH engine, and it wasn't until I produced an email with the old engine identification placard that they admitted there was an error.
They didn't talk me into it. They offered it as a possible solution, I told them not to touch it until I had time to research it, and then I would let them know how I wanted it fixed.
I made the decision based on the pros outweighing the cons for ME.
No incentives were offered. The rep tried to tell me I would need to buy the prop, so I very quickly told him that their mistake will be costing me nothing, the service manager came out to talk and confirmed that they will eat all costs.
'85 2001 454
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 10:45am
I appreciate all the info, and I did take it into consideration.
I am content with my decision, I'm aware of the cons of value depreciation and non-standard build, starboard listing, handling, etc.
No plans to sell, and LH will fit my needs fine.
'85 2001 454
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 10:46am
Oh, I just thought about this, does my alternator need to be changed as well?
'85 2001 454
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 10:57am
Technically the fins on the alternator should be changed, but not sure if it's really necessary. LH drives can be easier dock.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:00am
Thanks.
'85 2001 454
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:03am
I’ve repeatedly have heard NOTHING good about ANY Tommy’s nationwide. Best luck.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:07am
No need to change anything on the alternator.
PCM used the same alternator with the same cooling fan/fins for either rotation.
They only list one part number for the fan.
For example if you have a Prestolite, there's one fan number regardless of direction.
If it's a Mando, only one part number for the fan regardless of direction.
Like Bruce mentioned some alternators have directional fans, not yours though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:09am
I'm firmly in the camp that says that no matter what hull you have and what rotation you have, moving weight around will have an effect on the ride attitude.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:21am
I'm firmly in the camp that the Ian only wants confirmation that he made the right decision,,,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:31am
There is no doubt, but all I can say in my 2001 when it had a LH engine I found myself driving from a knee on the passenger seat regularly, same boat after converted to a RH prop with a trans/shaft/prop swap and the same usage and I haven't driven from the passenger seat in the 8+ years since.   Of course my weight does fluctuate quite a bit... Id take a LH engine over no engine to be sure but anyone saying they are equal in this application is blowin a bit of smoke even if they work today at the company that made that boat 30 years ago .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:37am
I haven't taken an exact count on the LH/RH opinions but it sure seem the overwelming is for going RH. In fact, I may be wrong but remember only one saying the LH won't matter!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 11:55am
When I head out in the boat by myself, I take my inflatable doll for movable ballast.
Since air doesn't weigh much, we fill her with jello to add some weight
Some days I dress her in a white long sleeved shirt and a white wig.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 12:19pm
How in the world did this turn into a conversation about you and Quinners old girlfriends
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 12:23pm
Come to think of it, Quinner did tell me she was well broken in and went both ways
I just figured she didn't care if the boat was LH or RH rotation.
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 1:10pm
Hey Ian, i think I know where you can get a sweet tower for that boat! hehe.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 1:15pm
No, I started this thread because I blew my engine. I ordered all the right stuff, and the shop made a mistake. I sought advice regarding the "broken transmission" and y'all were able to diagnose and help me identify a huge *************** up.
I sought opinions, and experiences, and weighed them all, and then made a decision for myself and my situation.
Since then I have been sharing my experience with y'all, as it seems many of you are curious about the outcome.
'85 2001 454
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 1:18pm
yes, a second tower would be helpful
She's in pre-op now. Surgery will happen next week. She's getting a new heart!
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 1:20pm
Should have looked at the first page...... how do you get all this egg off?
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 2:48pm
I like it! Add a second tower and hang a hammock between!!
'85 2001 454
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-14-2018 at 3:16pm
Oh she cares,believe it or not she's pretty high class. She came with the Paragon
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2018 at 3:24am
Well, tomorrow is the day that I'm supposed to get the boat back. We shall see if the shop can make this timeline, and how they handle this massive screw up
'85 2001 454
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2018 at 9:43am
Good luck man. Look real close at everything like mounts, hose clamps, cable ties etc. When a mechanic (or anybody for that matter) has to do something the second time less care is generally taken. The little detail things don't get done. So take a real good look. Keep an eye on the shaft seal, make sure its not leaking or getting hot or wobbling.
Enjoy your Fathers Day weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2018 at 9:46am
. Look real close at everything like mounts, hose clamps, cable ties etc. .
I'd go as far as checking strut/shaft/engine alignment. I don't have a strong feeling about Tommy's "techs".
