  New Posts New Posts RSS Feed - 330 pcm replacement or rebuild?
Snow247 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snow247 Quote  Post ReplyReply Direct Link To This Post Topic: 330 pcm replacement or rebuild?
    Posted: May-08-2018 at 6:43pm
Ok, first off I'm going to start this saying I'm an idiot. This is my first post and I'm a little embarrassed. The only boat I've owned was a 1994 genesis i/0 I bought for a few grand. I've been saving up for years for a nautique and found a great one. A 2004 sv211. The guy said he was getting married and needed to sell it. It was hours away and I was too stupid to find someone to inspect it. I bought it, not knowing too much. Anyways fast forward to this past weekend I put it out on the water and the engine bay starts filling. I pull it off the lake and go home and find 2 freeze plugs (or casting holes) popped out. I put them back in the best I could. I know I need to check my oil and see but I havmt had time yet. Any ways let's just say the block got cracked. What's the cheapest option?
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2018 at 6:53pm
Lets just say it didn't crack, pop the plugs in, check the oil and hope for the best.   Other than that costs depend heavily on how handy you are and what tools you have available. IF you are having others do the work then the options become more limited as the labor costs will be high and justify basically a drop in bobtail.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snow247 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2018 at 8:39pm
This may sound stupid but my last boat, I took it in to the mechanic when I first bought it and he said there was tons of oil in the pan. He then did an oil change, ran it for awhile and never had anymore water in the oil. With my new boat, even if i find water, should i do an oil change and check again? Before spending 8-9k
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snow247 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2018 at 8:40pm
Sorry I ment to say water in the oil
gt40KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gt40KS Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2018 at 10:18pm
First, I'd check the plugs to see if there was intrusion into the cylinders. Then change the oil & filter and do a fake-a-lake test to see fi there's any obvious leaks. Watch the temp carefully and listed for odd noises, shutting it down immediately if any develop. If not, let it come up to temp and shut it down, then check the oil for signs of water. If unclear, you may need to drain the pan again to confirm. Others may have different advise or additional thoughts.
And BTW - Welcome to the site!   Sorry it took something like this to get you here
JCCI
1995 Ski Nautique GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote samudj01 Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2018 at 11:58pm
While I am not an engine guy, I feel for your situation. I have my fingers crossed for your engine. You at least are in the right place. Listen to these guys and at least you will know where your engine stands, and hopefully those casting plugs fell out before damage. If so you could be boating soon. We bought a 78 tique with the seller telling us the engine was f’d from freeze. He was wrong. The guys on this site led us step by step through engine troubleshooting 101. Good luck. And thanks to those who give advice, we needed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Snow247 Quote  Post ReplyReply Direct Link To This Post Posted: May-09-2018 at 10:37am
Thanks everyone, I'm going to dig into it today and let you all know the results. Pretty nervous but it is what it is
shierh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shierh Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2018 at 1:14pm
One thing to consider, if you engine is not cracked your exhaust manifolds still could be.
Rule out engine crack but remove exhaust separately and rule out internal cracks.
