Loss of Electric to the dash |
gross
Newbie Joined: March-03-2016 Location: New York Status: Offline Points: 4 |
Posted: May-09-2018 at 8:23pm |
Hello, I have a 1989 SN 2001 and towards the end of last season I started having an electrical issue. I turn the key in the ignition and the starter clicks but then all power is lost to the dash. It doesn't happen every time and unhooking the battery seems to reset it. Has anyone had a similar problem or know what the issue could be?
Thanks! |
gt40KS
From what I understand the wiring harness connector (engine compartment) is prone to having issues over time. if I'm not mistaking, the power to the dash comes from a red?? wire within the harness. I'd start by checking if you have power before and after the connector. I'm getting ready to swap mine out due to a couple of these pin failures. But you may be able to fix the issue by thoroughly cleaning the contacts and apply some dielectric grease to help with further corrosion.
JCCI
1995 Ski Nautique GT40 |
Grayden,
Have you cleaned your battery posts and the battery cable terminals with a terminal/post wire type cleaner? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10641 |
Sounds like whatever cable you're disconnecting and reconnecting has a lousy dirty connection that can pass a small amount of current like the current to the coil in the solenoid but not a large amount of current like what the starter draws..
I'd combine the 2 posts above and use the diagram below to give all your cable connections a good cleaning to prevent future problems too,and don't forget the spot where the negative battery cable is bolted to the block When you're done you'll understand your electrical system a lot better Diagram courtesy of TRB productions It should be just like your wiring |
