  New Posts New Posts RSS Feed - Bimini top
Bimini top
Peacock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peacock Quote  Post ReplyReply Direct Link To This Post Topic: Bimini top
    Posted: May-23-2018 at 3:08pm
My 1988 2001, came with what looks like a homemade sun blocker (Bimini top). I am looking for pictures of what an original bimini top looked like. Or did the 1988's not come with one?
If they didn't come with one, what do the rest of you do for a sun blocker?
dgabler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgabler Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2018 at 7:56pm
http://www.correctcraftfan.com/reference/bview.asp?id=55#image24 is a stock photo. will see if I can get you one tonight from mine.
Post Options Post Options   Thanks (1) Thanks(1)   Quote dgabler Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2018 at 11:55pm
Here you go:
Dimensions
Height : 29
Front-Back: 52
Width : forgot to measure
The bimini was made by Adlee in Corona so they should have a template to go off of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2018 at 12:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peacock Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2018 at 10:19am
Welp, that shows me that mine is some kind of aftermarket junk. Now if you look at my boat you will see that the previous owner installed a ski tower. It does get used everyday when it's in the water.
I'm a thinking the proper top framing   will not work with the ski tower. Whats your thoughts? It appears there never was a factory top, I see now hinge point mount nor clips for the straps.
Also, where could I but the correct top and frame? Or is it more along the lines of, build one?
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2018 at 11:57am
Originally posted by dgabler dgabler wrote:
Here you go:
Dimensions
Height : 29
Front-Back: 52
Is there a reason that you have on backwards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgabler Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2018 at 1:18pm
Actually I had not realized it was on backwards till you mentioned something. PO installed it that way, possibly to accommodate the big air pylon? Will have to flip it now I have removed the pylon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2018 at 3:34pm
Backwards installs usually permit the Bimini to lay flat on the deck when not in use
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: May-24-2018 at 4:41pm
The Pylon theory makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2018 at 12:52am
That’s my reasoning as well. No,one else knows it’s bacerds unless they are on this site!
s_kelley2000 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote s_kelley2000 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2018 at 12:12pm
How about mounting it to the tower? Obviously I have a different tower but you should be able to modify what I did to work for you if you want to go that route. Here is the link   Let me know if you have questions.
1999 Python Super Sport
Timr71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timr71 Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2018 at 1:11pm
Mine is also on the way it is in the picture. It lays forward of the windshield when I put the boot on. That allows it to stay on the boat when it's put away at the marina. And, that's the way the install directions from tower biminis says to put it on. You could still call it backwards if you like though. :)
mark c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2018 at 7:12pm
Didn't even realize Biminis went back that far on the smaller boats. this is all I remember from back in the day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2018 at 7:48pm
More appropriately called a "convertible top" rather than a "bimini". Yes, pretty popular before the advent of the bimini.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-25-2018 at 9:14pm
RichK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichK Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 1:54am
I think Adlee is gone, no? My 95 has an Adlee.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichK Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 1:57am
Here you go:
Dimensions
Height : 29
Front-Back: 52
I think Adlee is no longer, correct? My 95 SNOB has an Adlee as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 2:23am
I thought they were called Navy tops. I'll be disappointed if Ken does not know
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-28-2018 at 9:18am
Sometimes you just get disappointed Gary
Way back, we had a boat with one of those tops and it had zippered side windows and a back enclosure but I seem to think we called it the "top"
Oh and I spent some time in the Navy too
