Help identifying CC trailer and parts |
Wtrskior
Groupie Joined: April-23-2017 Location: Canada Status: Offline Points: 44 |
Posted: June-13-2018 at 1:26pm |
Starting to go over the trailer my 01 CB nautique came on. The previous owner had it registered as a home build and most likely because he couldn't find an ID plate on it, just like I can't.
- Any idea on where the ID tag may be? I've been told and it appears from looking at other boats/trailers, this one is older than the boat and was likely made by correct craft. this correct? Approximately what age and is there a thread or list of applicable parts I can find for it? I intend on putting new brakes, lines, coupler on it. Already bought new tires. have had the hubs and bearings inspected and apparently okay. I picked up what I think are the right oil seals, but not 100%. - What bearings, hubs, axle, springs, etc should I be on the lookout for? |
2001 Ski Nautique CB w/ GT40
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Pichers
Wtrskior
that would help wouldn't it...
Thanks(1)
90-92 Correct craft Trailer. I can’t tel if the guideposts are straight (angled) vs curved (vertical on upper portion), but little else distinguishes a 90 from a 91-92.
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1831 |
The guide posts pictured above are angled. You can see the opening on top of the starboard post.
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
Lol.
\ / \ *transom* / These guide posts are still straight lines Are the posts straight pipe or are there bends. They look straight to me, which on an angle from vertical would produce a non horizontal top... | | \ *transom* / |
Wtrskior
the guide posts are straight and in the V shape you suggest. They actually have what appears to be an aftermarket welded on threaded insert 1 1/4" ID to accept a threaded pipe ( I did find the correct threaded pipe but alas, they were too heavy, not enough thread would catch & both broke almost immediately)
If I can find some kind of aluminum threaded 1 1/4" posts that may work better. any insight here would also be much appreciated! |
Wtrskior
One of my burning questions is with respect to the jack.... appears there is no grease zerk??? probably about time to replace it anyways, but it still works pretty well!
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 378 |
Thanks(1)
If you look under the trailer at the rear you might see a white sticker with the serial number on it. They put a couple of them on the back side of the skirt and on the inside of the frame rail.
woodyelc
