  New Posts New Posts RSS Feed - Model Code Demystified
thelostscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thelostscott Quote  Post ReplyReply Direct Link To This Post Topic: Model Code Demystified
    Posted: June-26-2018 at 4:32pm
Hi all,
New member to the forum here as well as the boating community.
I live in the UK and have just purchased what I think to be a 1993 Correct Craft Ski Nautique that is in need of quite a bit of TLC.
But what I was hoping you could possibly help with is the Model Code I can see on a tag on the engine?
The code is showing PLD-PR-R12PP
Thanks in advance!
Newbie - Please be gentle!
mark c View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mark c Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2018 at 4:36pm
That's the engine code for a pleasure craft left hand rotation engine, the D is for 351cubic inch 240HP engine. The rest of it I'm not familiar with. The HIN should be on the right rear upper corner of the transom, or on the vessel capacity tag located in front of the throttle lever.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2018 at 5:49pm
At the top of the site page there is a reference tab. Under that tab you will find Engine Manuals. for most years.
PLD-PR-R12PP
p= Pleasure Craft Marine, Little Mnt. South Carolina
L= Left Hand Rotation, Trans changes prop to Right Hand
D= 351 Ford
P = Drive - Pleasure Craft Marine
R= Drive Rotation (Prop) Reverse
R= Right Hand Prop
12= Gear Reduction Transmission it is a 1:23:1 ratio
P= Speaks to fuel System like Carb , Throttle Body or Multi Port.
P= ? I was looking at a 2001 manual so you get the idea. There is a 93 manual in the reference.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2018 at 5:50pm
Double post
Post Options Post Options   Thanks (0) Thanks(0)   Quote thelostscott Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2018 at 6:17pm
Thanks both, much appreciated!
xxchrissixx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote xxchrissixx Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2018 at 6:56am
Hi i bought a 2001 with PCM machine model number is PRK WR R10 Serial 251024
TO1104XR can anybody tell me something about this machine?
thank you and best regards from germany
christian
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2018 at 9:14am
That engine tag (PRK-WR-R10) says that you have a reverse rotation 454 Chevy with a 1 to 1 Borg Warner transmission and it has a right hand propeller.
The K tells you it's a 454
I don't have a clue what the "TO1104XR" means    Where is that number located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote xxchrissixx Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2018 at 9:19am
ok perfect thank you, the TO1104XR is on the same lable.
best regards christian
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2018 at 9:49am
The manual in the link will have some good info for you Chris
It;s from the reference section here on CCF
