Model Code Demystified |
thelostscott
Newbie Joined: June-26-2018 Location: UK Status: Offline Points: 3 |
Posted: June-26-2018 at 4:32pm |
Hi all,
New member to the forum here as well as the boating community. I live in the UK and have just purchased what I think to be a 1993 Correct Craft Ski Nautique that is in need of quite a bit of TLC. But what I was hoping you could possibly help with is the Model Code I can see on a tag on the engine? The code is showing PLD-PR-R12PP Thanks in advance! |
Newbie - Please be gentle!
mark c
That's the engine code for a pleasure craft left hand rotation engine, the D is for 351cubic inch 240HP engine. The rest of it I'm not familiar with. The HIN should be on the right rear upper corner of the transom, or on the vessel capacity tag located in front of the throttle lever.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3888 |
At the top of the site page there is a reference tab. Under that tab you will find Engine Manuals. for most years.
PLD-PR-R12PP p= Pleasure Craft Marine, Little Mnt. South Carolina L= Left Hand Rotation, Trans changes prop to Right Hand D= 351 Ford P = Drive - Pleasure Craft Marine R= Drive Rotation (Prop) Reverse R= Right Hand Prop 12= Gear Reduction Transmission it is a 1:23:1 ratio P= Speaks to fuel System like Carb , Throttle Body or Multi Port. P= ? I was looking at a 2001 manual so you get the idea. There is a 93 manual in the reference. |
Donald80SN
Double post
thelostscott
Thanks both, much appreciated!
xxchrissixx
Newbie Joined: August-21-2018 Location: D-69412 Status: Offline Points: 2 |
Hi i bought a 2001 with PCM machine model number is PRK WR R10 Serial 251024
TO1104XR can anybody tell me something about this machine? thank you and best regards from germany christian |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10669 |
That engine tag (PRK-WR-R10) says that you have a reverse rotation 454 Chevy with a 1 to 1 Borg Warner transmission and it has a right hand propeller.
The K tells you it's a 454 I don't have a clue what the "TO1104XR" means Where is that number located? |
xxchrissixx
ok perfect thank you, the TO1104XR is on the same lable.
best regards christian |
The manual in the link will have some good info for you Chris
It;s from the reference section here on CCF link |
