mounting brackets for gas tank |
chuck kemp
Groupie Joined: June-29-2014 Location: tennessee Status: Offline Points: 58 |
Posted: July-16-2018 at 10:39am |
LOOKING FOR THE MOUNTING L BRACKETS THAT HOLD THE GAS TANK TO THE STRINGERS 1983 2001 SN. MY STRINGER MAN HAS LOST THEM I HAVE THE STRAPS THANKS
Chuck, Sounds like you found the straps and now need the brackets? They are typically blocks of wood just to keep the tank from sliding laterally. |
Chuck, How about posting some pictures of the stringer job. It's always great for reference especially since we lost so many when Photobucket got greedy. BTW, you don't need to shout. I can hear you all the way up here in Wi. (your caps lock is on) |
Pete, you may be thinking of an older style of tank mounting system. At some point in the 80’s, cc went to angled aluminum brackets that the tank sat on and aluminum straps with threaded ends that go up and over the tank. A bit nicer than the wood strips and blocks used through the 70’s.
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1143 |
I may have some. I will check.
ScottZ
