  New Posts New Posts RSS Feed - mounting brackets for gas tank
chuck kemp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck kemp Quote  Post ReplyReply Direct Link To This Post Topic: mounting brackets for gas tank
    Posted: July-16-2018 at 10:39am
LOOKING FOR THE MOUNTING   L BRACKETS THAT HOLD THE GAS TANK TO THE STRINGERS   1983 2001 SN.    MY STRINGER MAN HAS LOST THEM     I HAVE THE STRAPS     THANKS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2018 at 10:58am
Originally posted by chuck kemp chuck kemp wrote:
I m looking for the 2 straps to tie gas tank down    Mine did not return after stringers were replaced     THANKS
Chuck,
Sounds like you found the straps and now need the brackets? They are typically blocks of wood just to keep the tank from sliding laterally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2018 at 12:26pm
THANKS
Chuck,
How about posting some pictures of the stringer job. It's always great for reference especially since we lost so many when Photobucket got greedy.
BTW, you don't need to shout. I can hear you all the way up here in Wi. (your caps lock is on)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2018 at 12:44pm
Pete, you may be thinking of an older style of tank mounting system. At some point in the 80’s, cc went to angled aluminum brackets that the tank sat on and aluminum straps with threaded ends that go up and over the tank. A bit nicer than the wood strips and blocks used through the 70’s.
ScottZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2018 at 11:05am
I may have some. I will check.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2018 at 9:32pm
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
