  New Posts New Posts RSS Feed - Gelcoat Color Mixing
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Topic: Gelcoat Color Mixing
    Posted: July-31-2018 at 7:36pm
Curious to know if anyone has had success at creating color matching gelcoat for repair of a serious scratch or ding?
I have used a lot of the Spectrum Color gelcoat "patch paste" kits in fixing up the horrific gashes in my Silver Cloud colored hull and deck. That stuff is amazing and the repaired areas look as good as new. But now I am turning my attention to the Electric Blue and Charcoal Grey pieces of my hull. Some of the damaged areas are down to the glass (or deeper), so I can't just buff it out. The worst offenders are the screw-in snaps that someone installed for a boat cover. I want to get rid of those snaps, repair the other areas damaged and get the hull looking as good as new again.
I'm asking because a you cannot get a patch paste repair kit from Spectrum for 1993 Electric Blue or Charcoal Grey. A full gallon of gelcoat is well over $200, so I'd be spending quite a bit for 2 gallons a gelcoat, when I likely need maybe a cup or so of each color to do the repairs.
So, I'm wondering if I should buy some gelcoat with the pigments and try to match the colors myself? Or would that just be a waste of time and money and I should just buck up and pay Spectrum?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2018 at 8:10pm
Kevin,
I have done some patching that did require a fair amount of gel but not to the point of needing a quart or even a pint. The larger patch kits come with a decent amount of gel so I'd go for one of them. Mix multiple small batches but without the hardener. Use the pigments in extreme small amounts at a time so you don't over pigment. I use the tip of a tooth pick to slowly match (hopefully!!) the needed color. Mix the same amount of pigment in all the small batches. I also mask around the fill with fine line tape. Then when you sand, you don't sand much of the surrounding area. When you get down to the thickness of the tape, remove it and sand flush/feather.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2018 at 8:24pm
Gelcoat and tints are cheap, you have little to lose by attempting the repair yourself. If you’re unhappy with he color match, dremel and try again- or pay a pro.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2018 at 8:55pm
It would get you close but the chances of Spectrum color match are slim to none anyway Kevin. I spent the bucks one year to match the Mustangs deck, cut out a piece out behind the back seat and sent it into Minicraft. Close but still needed tinting. Was not worth the expense.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2018 at 9:42pm
    +1
I just posted on another thread how the available color match wasn't a color match for a 91 base color white. It needed tinting.
Also, you will be surprised how good it looks with the snaps removed and the hull sanded/buffed. I know an Orange Promo that most folks (even a few on this site) don't realize had snaps once removed. The holes are small and only annoying to the owner!
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-31-2018 at 10:22pm
+1 on kit mix. Only you will notice any color mismatch.
Do the tiniting matchup in strong light, sunlight is best IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2018 at 12:09am
Super. I'm going to give it a go on my own and do my best. Thanks for the help. The idea of surrounding the area with tape is a great one, Pete. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2018 at 6:55am
Kevin,
Keep us informed on how it goes. Also, I don't recall any threads showing gel repair. Take some pictures and it would be a great addition to the FAQ's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2018 at 10:07am
Another thought - the original gelcoat may have faded some. You might want to wetsand & buff around the repair before doing the color matching.
Otherwise, you might be in for a surprise when you do final buffing.
Blamey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blamey Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2018 at 2:41pm
I like this guys videos a lot. I am sue there are other ways to watch he gel but I thought this was a good overview with some useful tips\ideas.
https://www.youtube.com/watch?v=yoURRmkD8MY
96 Super Sport
Previously: 95 Sport Nautique, 1980 Ski Supreme
