Parting 2001 PCM 5.8 HO 25th anni. GT-40 310HP |
fj60erik
Newbie Joined: August-01-2016 Location: Bradenton, FL Status: Offline Points: 25 |
Posted: August-11-2018 at 7:15pm |
Hello all,
I'm parting out a 2001 PCM 5.8 HO 25th anniversary GT-40 310HP. Complete engine excluding exhaust manifolds. GT40 cylinder heads in good condition. Engine has a burnt piston in one cylinder most likely due to a bad injector. minor scoring in that cylinder will need to be bored and rebuilt. Will sell complete long block minus raw water pump, alternator, intake and fuel injection for $350.00 or let me know what you need. Raw water pump, distributor, alternator is a Arco 60108, upper and lower intake, good thermostat housing, brackets, good ecm and mount and harness, both fuel pumps, etc. Again let me know what you need, heads are off to diagnose bad piston. I can text pictures if you need to see something. Thanks, Erik |
kylem428
Senior Member Joined: May-31-2005 Location: United States Status: Offline Points: 263 |
How much for your arco 60108 alternator and also how much for 2 day shipping to 54501?
Thanks! Kyle |
fj60erik
sent you a PM.
Thanks, Erik |
Sent you a pm Erik, Thanks Gary
fj60erik
Short block is sold, raw water pump sold, fuel pumps are sold
Still have ECM and bracket, GT40 cylinder heads, alternator, Arco gear reduction starter, Upper and lower intakes, raw water pump bracket, pulleys, misc Let me know what you need. Thanks, Erik |
fj60erik
Sold cylinder heads.
Remaining is ECM and bracket, harness, Upper/lower intake, throttle body, flame arrestor, pulleys, raw water pump bracket, motor mounts, alternator, starter, distributor. Let me know what you need. |
Got the things I need from Erik today,fast shipping and well packed.
All you guy's talking about fuel injecting your engine,here you go- factory injection. Stuff does not come up too often. He has everything but the pumps |
fj60erik
ECM has been sold,
Still have bracket and harness, upper/lower intake and throttle body, dist., raw water pump bracket, pulleys, alternator, starter, bellhousing, motor mounts. |
mattradintz
Groupie Joined: August-21-2018 Location: Wisconsin Status: Offline Points: 46 |
What is the alternator brand and model#? And starter please?
man0seven
Senior Member Joined: September-16-2018 Location: Utah Status: Offline Points: 122 |
Do you still have the distributor?
2005 Ski Nautique
fj60erik
Yes the distributor is still available.
I can get you a picture after work today if you are interested. Erik |
man0seven
I would be. Please do. PM sent also.
2005 Ski Nautique
man0seven
I am interested in the alternator, pulleys, and electrical cluster attached to the throttle body.
2005 Ski Nautique
fj60erik
Updated 10/26/2018
I have remaining: upper/lower intake and throttle body, misc sensors, coil, module, raw water pump bracket, pulleys, alternator, starter, bellhousing The Arco alternator and starter are listed on Ebay. Thanks |
sport1999
Senior Member Joined: May-10-2015 Location: Florida Status: Offline Points: 313 |
I would list the upper/lower intake on e-bay. I believe I sold my lower ($250+) and upper (~$150) pretty fast. Both should fit in separate large flat rate boxes for shipping.
fj60erik
Thanks, that will probably be the next step if no one here needs it. Good idea on the flat rate boxes. |
Mike9812121298
Senior Member Joined: March-24-2017 Location: Seattle Status: Offline Points: 139 |
Looking for temp gauge?
fj60erik
Sorry I don't have any gauges.
I might have the temp sender if you need that? |
NCH20SKIER
Grand Poobah Joined: December-16-2004 Location: United States Status: Offline Points: 2207 |
Flame arrestor?
'88 BFN |
fj60erik
I have the flame arrestor.
Sending you a pm. |
