Gel Coat |
behindpropeller
Posted: August-17-2006 at 11:13am |
Can you order the correct color gel coat from the factory?
Thanks Tim |
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1128 |
You can get it from Mini Craft in Florida. You can pick the color by manufacturer. I am not sure if you can get it from CC or not.
Mini Craft |
David F
Yes, CC can get the gel coat to match the original gel coat for your boat. Just remember, you will get non-faded gelcoat. However, you must order 1 gallon minimum and it cost about $180.00 per gallon.
I did just this with my '93SN and the match was surprisingly spot on. However, not sure about the older boats. |
BrentAL
Newbie Joined: August-03-2006 Location: United States Status: Offline Points: 13 |
I talked to Southeast Correct Craft yesterday and they said to order it from spectrum color. The patch kit looks good to me if you just need a little.
http://www.spectrumcolor.com/ Brent |
96 sn 196
oldskiboat
Groupie Joined: June-16-2006 Location: United States Status: Offline Points: 92 |
The problem is that your gel coat is probably not still the same shade as a new boat. You may want to go to a fiberglass restorer and have them match the color for you. I did it for mine and just had to get the amount he mixed.
