  New Posts New Posts RSS Feed - Oil sheen in watet
Oil sheen in watet
Steamer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steamer Quote  Post ReplyReply Direct Link To This Post Topic: Oil sheen in watet
    Posted: August-22-2018 at 1:39pm
Has anyone seen oil sheen in water in and around there boat after shutting down. Watercontinues to circulate as the engine cools down so its coming out the exhaust.No oil loss noted.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 2:44pm
Could just be running a bit rich.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Could also be teak oil from the platform...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 2:47pm
Could be your trans as well, keep an eye on its oil. It does not take much to make a sheen
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 2:49pm
X 2
What year/model are we talking here
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 4:01pm
I agree. Is there any indication of water in the trans fluid?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steamer Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 11:21pm
Thay was a thought, but gas vaporize's pretty quick. A drop of Dawn and it disappeared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steamer Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 11:23pm
Oil is clean, no loss noted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steamer Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 11:28pm
A item of interest, changed over to straight gas this summer, and then changed back to 93 octane to see if problem disappeared, nope.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-22-2018 at 11:54pm
My trim tabs on my Shamrock leaked just enough to put oil in the water,never noticed any loss in the tabs reservoir. It does not take much to see it in the water. Just keep an eye on the trans level and color.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steamer Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2018 at 8:44pm
1992 Ski Nautigue
875 hours on engine.
Carb tuned, turned jets in from 1-1/2 turn rough setting.
16 " Hg , still seems to be running rich. Any suggestions
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2018 at 8:01pm
What do the plugs look like?
