  New Posts New Posts RSS Feed - Heavy Duty Rubbing Compound
GHTILL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHTILL Quote  Post ReplyReply Direct Link To This Post Topic: Heavy Duty Rubbing Compound
    Posted: August-25-2018 at 6:23pm
Any suggestions on rubbing compounds for gel coat. I'm repairing many nicks and gouges
on my 1993 196 gel coat finish. I've tried many different ones with mediocre success. The best one I've tried is the 3M Perfect-it EX. Any help?
Gregg
TWSS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2018 at 6:48pm
Gregg,
Here's a link from the FAQ thread in the maintenance section. Buffing and sanding gel
throttle out View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote throttle out Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2018 at 10:12am
Marine 31 chemicals from autogeek.net are the best I've used so far.
https://www.autogeek.net/marine-31-boat-care-kit.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2018 at 10:20am
Sam,
What other products have you used for a comparison? Have you used the Marine 31 after a wet sanding?
Here's a direct link to Autogeek and Marine 31 but it's looks like they only have kits for buffing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote throttle out Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2018 at 9:24am
I have used numerous Meguires chemicals, Wizards (also good), 3M, along with a couple random odd ball chemicals my local marina was stocking for a time.
I used the Marine 31 directly after wet sanding and was the correct choice in my opinion.
Look their Marine 31 section over good Paul, you should be able to buy individual items as well as kits. If you continue to scroll down you will see each individual item. I went with the gel coat oxidation removal kit that came with the Flex DA polisher, but you will need a high speed orbital polisher (not dual action) to dig deep enough to clean up oxidation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2018 at 12:09pm
Sam,
Thanks for the feedback on the Marine 31. It's good to know there are alternates to the 3M standby.
BTW, I did scroll down on the Marine 31 link you provided and I can't see when compounds can be purchased separately. I'm still only seeing kits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2018 at 1:27pm
Pete,
try this page down to individual items
https://www.autogeek.net/marine-31-boat-care.html
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2018 at 4:36pm
3m super duty
Have you tried it yet?
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2018 at 4:38pm
Originally posted by gun-driver gun-driver wrote:
Pete,
Paul,
Thanks for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHTILL Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2018 at 6:40pm
Been too hot to crawl back under the boat. I've ordered the 3M Heavy duty. Can't wait to see the results.
The bottom of a Ski boat is probably the most neglected area of them all. I truly think that I can tell a difference on how the boat handles after it's done.
TWSS
