DUI iginition wires? |
Ubugarrity
Newbie Joined: July-22-2016 Location: 07821 Status: Offline Points: 4 |
Posted: September-09-2018 at 6:14pm |
Does anyone know what spark plug wires are needed for DUI Ignition? I would like to get locally if possible from auto store but would need a part number or vehicle reference.
Thanks |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 2822 |
You can go to the local auto parts store. Make sure that you get female HEI plug wires at the distributor end.
As this is a marine application, the typical "vehicle specific" approach can be hit-and-miss. The exhaust manifold and risers may require the custom approach. As such, the best option, IMO, is to buy a cut-to-length kit and build your own wires. JQ |
KRoundy
I purchased a special tool and a kit to make the wires myself. It worked very well and I highly recommend this approach. There should be a link in the FAQ. Hang on a second....
KRoundy
I found it! I did the same thing as JPASS, got the same crimping tool and everything - I went with red wires and they still look great. Custom fit is the best when switching to a DUI. Looks good, performs well.
Link for DUI installation |
Dreaming
I saw the custom fit wires on the shelf at my local speed shop a couple of weeks ago when I was shopping for carburetor gaskets. You may be able to find them locally if that is what you're after.
