Ford greay motor Paint color? 1990 |
BryanBend
Newbie Joined: August-13-2018 Location: Bend Oregon Status: Offline Points: 16 |
Posted: October-20-2018 at 12:05am |
Hello Does anyone know what the paint color is for 1990 Correct Craft ford motor? Grey. Thanks Bryan
1990 Ski Nautique
Need 1990 hull decals for Ski Nautique |
Gray color?
BryanBend
Yes motor is Gray: Like to find out the kind of paint and color to match.
1990 Ski Nautique
Bryan,
Post a picture of the engine so we have a better idea of what you have. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10641 |
Maybe Zach will be able to remind us what "grey" he used
Bill Hirsh, spray or qts, color Alloy. Much better paint than Duplicolor.
BryanBend
I ended up using VHT sp 995 at Auto Zone Matches well ! Thanks Bryan
1990 Ski Nautique
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 885 |
I tried this:
Now I wasn't going for an exact concourse match, but wanted that 'burnished' silver look of the original PCM of the era. I applied a base of DupliColor engine enamel (DE 1615 Aluminum), over which I immediately sprayed a light mist of DupliColor Pewter Metallic. (BGMo490). Extremely pleased with results. |
1994 Ski Nautique "Riot"
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Offline Points: 6147 |
Gary, that was a color I picked out myself. I think it is from Dupont and in their single stage line (no clear coat). I wanted something just slightly more vibrant than what was on the engine but not enough anyone would think man that doesn't look factory.
The "Burnished" silver look was just crappy paint from PCM turning a golden color over time. I can share the paint code when I get home for the silver I used. It is pricey to go that route but my engine still looks like I freshly painted I think on season 3 or 4 other than water spots I need to wipe off. Also FYI. "PCM Specific" spray cans are just aluminum Duplicolor engine paint with the labeling removed. I used that on my brothers 351 this spring. 3 coats of primer and 4 of paint and it's already got some rust popping through on areas of the block. Meh. |
MourningWood
You're so right.... As I recall, it seemed to discolor within the first 100 hours, and, as my boat has over 1400 hours on it, well......you see........... |
