  New Posts New Posts RSS Feed - GT 40 knock sensor
GT 40 knock sensor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: GT 40 knock sensor
    Posted: November-24-2018 at 11:01pm
Does anyone happen to know if there is a Ford part number for these? I'm missing it so I cannot look to see if there are any numbers on one. PCM wants 78 bucks which is about 3 times that of a Ford OEM. For example a PCM Map sensor is 293.58,I bought a new Motorcraft one for 35.00, a PCM PIP sensor is 132, I found a Motorcraft one for 23    Thanks for any direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2018 at 6:19am
There should be numbers on your knock sensor.
I would look at the aftermarket, Bosch, Standard ignition, Airtex, Borg Warner would all have these for sale.
Got Tiques View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Got Tiques Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2018 at 1:52pm
Gary, pulled mine out and only number is 5K12 on the flat of the hex and NTK embossed on the porcelain. Hopes this helps. Todd
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-25-2018 at 2:40pm
Thanks Todd that will give me a start. NTK is NGK's line of sensors is what I see so far....
