  New Posts New Posts RSS Feed - Raw water cooling flow diagram
Mogens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mogens Quote  Post ReplyReply Direct Link To This Post Topic: Raw water cooling flow diagram
    Posted: November-29-2018 at 2:59am
Hi
I have a 71-72 ish correct craft conqueror crusader 302 with 220HK
On the exhaust manifold there is a gasket just before the end piece where the exhaust hose is mounted. there is a stainless center in this gasket, this plate closes for water flow is it correct?
Is there a good overview of water flow in a drawing or manual. ?
My engine is with raw water cooling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2018 at 8:14am
Originally posted by Mogens Mogens wrote:
Hi
Hi Mogens
Page 32 of the manual in the link has a block diagram of the cooling water flow for raw water cooling on a Conqueror Crusader Ford from that time period
It's not exactly the simplest cooling system out there
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2018 at 10:05am
Mogens,
Could you post some pictures of the exhaust manifolds, the elbow (where the hose connects) and the gasket between the two. They would give us a better idea of what you have exactly. There is a possibility they have been changed/retro fitted at some point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2018 at 12:06pm
I agree, post a pic of the manifolds and that gasket. Several of us have conqueror crusaders and are familiar with the cooling system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mogens Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2018 at 2:21am
Hi
Here is a photo of the 302 still in the hull.
Its out now and in loose parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mogens Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2018 at 2:38am
I have 2 solid gaskets
Its either from the from or rear.
I did not see this before separating the part, if its in the front or back I cant tell.
Or it's a wrong gasket .
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2018 at 8:58am
I’m familiar with the manifolds and the cooling... I want to see these gaskets you’re talking about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mogens Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2018 at 7:18pm
Hi
Here is the 2 gaskets
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: November-30-2018 at 8:05pm
I do not recall splitting mine, but I would block the bottom. The 3-hole gasket should go on the front plate and the 1-hole should go between the manifold and riser.
Is that crusader blue? Pm me if you want decals.
