Help |
Author | ||
Gchris1988
Newbie Joined: December-01-2018 Location: Scotland Status: Offline Points: 4 |
Posted: December-02-2018 at 10:21am |
Hi all, I'm new on here, I have a 1979 ski nautique with a ford v8 351w
So I have a few problems and I'm not mechanically savvy with engines, but I know the basics, On removing the block drain and exhaust drain there was engine oil present. This would suggest to me that the block is cracked, cylinder head is cracked or the head gasket is away. There are hoses that we need to drain that drains are sheered and are bonded on with sealant and one exhaust manifold plug looks like it has never been off. So can’t get them out easily. What are my options, and what is the best route to take in repairing Help would be appreciated I'm based in scotland Thanks Chris |
Chris,
I moved my posts too. Be patient for more responses. We have a great group and a great knowledge base.
Apex
Newbie Joined: November-28-2018 Location: Indiana Status: Offline Points: 10 |
Chris, Have you done anything more with your engine? Are you saying oil came out of the exhaust manifold drain when you pulled it or just the engine block drain? I have never seen oil come out of an exhaust manifold drain and actually have to think about how that would be possible. Are you sure that you removed the correct drain plugs?
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 885 |
Chris,
Can you confirm (or not) the presence of water in the engine oil pan? |
1994 Ski Nautique "Riot"
