  New Posts New Posts RSS Feed - Martinique with Big Block 454
83martinique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Topic: Martinique with Big Block 454
    Posted: December-10-2018 at 6:39pm
looking to rebuild or replace starter on a 454, found some left hand rotation startes new at around $190. All i need is a brush set assembly,as my starter springs are shot, rusted in to a non usable condition. Any one know a place   for starter parts?
scott G
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:02pm
If you ever drive through Apopka might be worth stopping at Millikan Battery and see what they have.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:11pm
Assuming you have a reverse rotation Pleasurecraft 454 in the Martinique (it would have come from Correct Craft that way), it would have a rear entry starter and this diagram in the link would help you out with what rotation starter you would need if you decide to buy another one. It would be a clockwise rotating starter if all the above is accurate
And here's a link to the Arco starter that would be appropriate or you could cross reference to other brands
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:23pm
very helpful thanks for the info,I now know the rotation for sure,my first clue was the firing order, and now this confirms it , starter is a good price on the link you sent also
scott G
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:27pm
heading to apopka tomorrow so I will stop and ask
scott G
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:29pm
Just to be sure,
A reverse rotation 454 has a firing order of 1 2 7 5 6 3 4 8 going clockwise around the distributor cap.
Is that what you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:33pm
yes
scott G
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 7:41pm
Good, so you know what you have and what will work for a starter if you can't find parts for your present starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 8:34pm
found all the parts to fix starter on alternator starter wholesale for$20.77 . Ill let you know how it turns out . I either saved $140 bucks or wasted 20 and a few hours time
scott G
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2018 at 9:38pm
It's a chance I'd take
I didn't look too hard but I didn't see brushes for a Delco 14 MT which is what yours is
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2018 at 8:46am
Smithfamily View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smithfamily Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2018 at 9:11am
Late to the party and I see you got the parts from Milliken.
Good guys at TRS on silver star rd, Orlando. Was an old Scottys lumber. They can rebuild it for you if you run into challenges.
Js
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2018 at 9:49am
Oh yeah TRS. Better luck there no doubt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2018 at 10:51am
a few bucks cheaper than a new 30456
And if you were to want to save a little more money and a bit of weight too, you could get one of these gear reduction starters in the link.
It says it cross references with the original PCM Reverse rotation starter RA122008 and a pile of others including the Arco 30456
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2018 at 6:52pm
I'd take the chance too. I'm glad to hear that someone's going the rebuild route and keeping it original.    As long as the field windings show continuity and the armature tests good on the growler, then the rebuild will work. Speaking of a growler, I'd say there's a good chance Ken has used one many times and in fact may even have one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2018 at 9:28pm
You mean like this one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2018 at 11:47am
it is a 27 MT
scott G
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2018 at 1:02pm
it is a 27 MT
If it is a 27 MT it probably means a couple of things
One is that it's for starting big beefy diesels
Another is that you'll probably never find anything that says it's a marine starter with proper spark protection and USCG approval
If you find marine applications/approval, post it here, it'll be good info
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2018 at 1:13pm
Good thing I said probably since the link below is to a marine 27MT for a marine diesel engine.
Wrong rotation and wrong number of teeth but it looks like there are some marine 27MT's out there
Edit................ But a marine diesel starter isn't required to be ignition protected like one for a gasoline engine so that leads you to wonder about using a 27MT with a gas engine in a boat.
Cyclone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cyclone Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2018 at 9:13pm
I don't know much about diesels but why don't they need to have spark protection on their starters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2018 at 9:47pm
Flash point
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: December-13-2018 at 8:23am
Like the flash point link from Pete above says, the flash point is higher and diesel fuel won't cause an explosion nearly as easily as gas.
Because of this gasoline is classified as a flammable liquid, and diesel fuel isn't, strange as that might sound.
A diesel fuel leak in a boat's engine compartment can most definitely start a fire if it's spraying onto a hot enough surface like the exposed non water jacketed part of an exhaust manifold but it won't cause an explosion.
Kinda like an oil burner in a house or garage.
A fine spray of oil on the igniter makes a fire and doesn't cause your boiler to explode.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83martinique Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2018 at 8:43pm
Starter is rebuilt and operating . Fired up as soon as I cleaned points , Next step is tear in
to the Holley carb as it must have some floats stuck in place. summit had rebuild kit in stock for the carb
scott G
