Transmission Fluid Change |
Author | ||||
Otto Throttle
Senior Member Joined: October-02-2017 Location: Cleveland OH Status: Offline Points: 369 |
Posted: January-12-2019 at 5:02pm |
1999 SN probably needs a change of fluid...looking for suggestions on type and methods!
Otto |
Otto
baitkiller
This has been covered a bunch of times. Most people use a little pump but be warned, A plastic tube can get caught in the gears. I put a hose on the cooler return fitting and let the transmission pump itself out. YMMV I would suggest a site search.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10646 |
Here are the search results for "correctcraftfan PCM 1.23 to 1 transmission fluid change" courtesy of Google
It'll keep you reading for a little while You'll even find stuff from other websites link |
Otto Throttle
Thank you kind sir! I don't know if it has ever been changed!
Otto |
Otto
relake
Senior Member Joined: May-18-2016 Location: IN Status: Offline Points: 126 |
I use an old pump from a large head and shoulders shampoo bottle that I thoroughly cleaned. It fits into the dipstick tube and is the perfect length, it is a very sturdy tube too.
I pump the fluid into a yogurt or cottage cheese container, then funnel it to an empty oil container to get the correct amount that I take out, it is typically right at 2 quarts. The whole process takes less than 15 minutes and less than $15 for fluid. |
Otto Throttle
That is fantastic! That gets the "Tim the Toolman Taylor Award!" i was going to do the same as far as pumping into a measurable container...but the other is GOLDEN. I assume you have to do it cold so the pump doesn't malfunction...Correct?
Thanks a lot!!!!! Otto |
Otto
SNobsessed
That is what I used. Beauty supply store $2. IIRC, I put a pc of copper tube to go into tranny long enough that it couldn't be lost inside. (Press fit into the plastic tube on pump)
I think there is a small hole, 1/2 way down, that you need to go into to get near bottom of the case. |
relake
The pump that from the head and shoulders bottle has the same length of tube as the dipstick, so it reaches the bottom without fear of losing anything into the transmission. If memory serves me right, I think it was about 130 +- pumps to a quart.
In fact, when inserted, there is just enough head space with the pump to get good pumping action without spilling or squirting onto anything except the secondary container. Yes, I changed cold, it was the last task competed during winterization. |
kapla
I use lubrication syringe, with a clear plastic hose, you want to make sure you get to the bottom of the trans carter to make it to pump. You will know is in the right location if it actually pumps out liquid...
I did it last week and i pumped out almost 2 quarts... |
<a href="">1992 ski nautique
shierh
i drain into bilge and pump out over board into the lake
Steve, You and Ross must be related!
shierh
well in the day it was actually common practice on commercial off shore boats.
Did it in need when taking a 58tc from st pete to Mobile bay. one 1271 blew oil line and fried the engine. Had leaking around a rudder post gland and it was not accessible due to cabinets that were built out of 3/4 ply that covered the access panels. (not my boat) . Left a pretty substantial slick that occurred every time pumps had to operate over the course of 36 hours of running. or limping at 8kts. |
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 758 |
Mityvac 7400 1.9 Gallon Fluid Evacuator, best one I have ever owned. I use it for everything, it goes on sale at west marine every now and then...but everywhere carries it. I promise you won't be disappointing, throw the drill sucker and others in the garbage.
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
