Engine Rebuild |
Post Reply | Page <123 |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
I did figure these wires out they were for the bilge pump and blower |
John, Considering the wiring problems, I wouldn't be surprised. The one way to find out is to go after the wiring tomorrow. |
jterr
John, did you get the VOM out and check that gray wire. Also, disconnect the gray wire at the tach an check it for voltage when you turn the key on. Report back what you get QUOTE] Pete just curious about this reading? Alrighty then-here are the results Disconnected wire from Tach got a reading of 11.01 volts with key in on position. |
John, Thinking again about getting the voltage reading from the gray sender wire at the tach, I should have told you to also disconnect the positive wire on the coil. Try it again and see what you get. The idea here is to make sure the gray wire isn't connected someplace else since you mentioned you other connections in the wire harness/loom. |
jterr
Wire from Tach no volts.
Also read that a dead light bulb could be a cause; but after disconnecting it as it is burned out same pegging. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10681 |
JT
With the gray wire hooked up to the coil(-) your reading of 11 or so volts is normal with the key in the Run position depending on the points position. Assuming you have points, if the points are open when you turn the key to Run, you'll have the same voltage as what's going into the (+) terminal of the coil from the ignition switch. If the points are closed when you turn the key to Run, you'll have no voltage because the coil is going to ground through the points. If you pop the cap off and see if the points are open or closed, you'll know what you should be seeing for voltage based on the above. The tach needs 12 volts from the key, a ground connection and then the pulse signal to give indication comes from the gray wirehooked to the coil (-). The pulse itself is that change from 12 or so down to zero volts every time the points operate. With it pegging when the key is turned to Run, you should probably look on the back for a small switch for selecting the input. It might be inside a little hole or you might be able to see it pretty easily. Most tachs have this selector. With a little "tweaker" you can move that switch from it's present position to the next position in either direction and cycle it back to where it was a couple of times. This will clean the contacts if they're dirty or have a little corrosion. Different tachs are labeled differently but you should find the switch in the 8 cyl position and end up with it back there too.. Then with all the wires hooked up normally, it may work again. It won't hurt to try this. I have a tach that does just what yours does and needs this every few years or so And then again, maybe it's just dead If it's an electronic ignition in the distributor, all the same info pertains Just an oh by the way....................your dash diagram shows an ammeter setup and your photos in other threads for this boat show a voltmeter next to the ignition switch so that explains your missing red wire you mentioned. |
Good. So now you know the gray wire isn't connected to anything else. |
jterr
Well I took all gauges out and cleaned/reconnected and wired by the Diagram above. I did find the 3 connectors on back of Tach and moved around and back to 8 cyl.
After all the above Tach still pegs so maybe it is bad. Will see what it does after I get engine running again when don with Carb. Thanks for all the info |
John,
How's you back from crawling under the dash? I know it gets tougher and tougher as time goes by. |
jterr
Little stiff, but with 2 bad shoulders and knee I'll deal with it. I still have to finish carpet under there yet Thanks Was hoping to go to Lake Sunday for the water test but 80 % chance of rain |
jterr
It never ends
Decided to make sure engine runs after all the wiring issues. Engine was running ok and I never went into the Distributor Check this out?? You could almost drive a truck through the gap This as close as I could get |
JT That's some kind of magic distributor you got yourself there In the first picture the points would never close so it's seems kinda hard (like impossible) to make a spark and make the engine run. In the second picture, it looks like they're still open and they'll never close unless it's camera angle or lighting or something making it look that way, making it equally impossible to get a spark. |
jterr
After looking closer the arm has gotten bent and actually shorted on the screw. Kinda straightened and it runs again???
Still the Tack pegs and stays there even with engine running ; think I will buy another and try. |
jterr
Just a quick question . Any idea why I'm not getting e-mail notifications???
Look down at the bottom of the message box. There's a box to check for email replies. If you logged out and then back in, I believe you need to check the box again |
jterr
It's checked now but will log out and see if that works. Thanks |
