Bent fin |
SunFun
Groupie Joined: March-03-2018 Location: sc Status: Offline Points: 40 |
Posted: March-04-2019 at 11:20am |
The back fin on my SN is bent slightly therefore not lining up exactly with the other two.
Do you guys think it makes enough of a difference in performance to replace it or straighten it? Thanks |
1989 SN 2001
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
Slightly bent is probably okay. If your OCD like me then remove it and straighten it out..
SunFun
I see that the fins are screwed on so I assume they aren't too difficult to remove. Are they hard to straighten?
1989 SN 2001
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Online Points: 3594 |
I believe that like your prop strut they are installed with the mounting screws and some tough 5200 sealer.
I was able to remove mine by removing the screws and then hammering some wood door shims between the fiberglass and the brass fin. By using 2-4 shims and tapping back and forth between them it eventually popped off but that glue is tough. Home Depot, Lowes or your local hardware will sell wood door shims for about $3. a pack and it will give you plenty for this type job. The wood did not damage the fiberglass at all. Many on here will reinstall with 4200 rather than 5200 because a future removal is much easier. I chose to apply the 5200 again and I know what I am up against if it needs to come off in the future. I hope that does not happen but you never know. |
