oil pan needed |
camron18
Senior Member Joined: March-05-2015 Location: Michigan Status: Offline Points: 164 |
Posted: March-19-2019 at 4:22pm |
Looking for a preferably used or cheap oil pan for pcm 351
Let me know thanks |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
Lots of reading and info in the link, including some part numbers and comparisons of stock and aftermarket pans.
Not knowing how much clearance there is between the pan and hull, you'll have to decide if the truck pan might work on your Hydrodyne.. The aftermarket pans have the plug on the bottom but if there's room for a drain fitting to a hose you'd be all set. You also need the oil pump pickup to match the pan. If you're looking at the aftermarket stuff look for the pan and pickup for an 84 F 250 with a 351. Don't get confused with 302 pans which won't fit link |
PM'd you
