  New Posts New Posts RSS Feed - 67 SN in California back to life
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Topic: 67 SN in California back to life
    Posted: March-26-2019 at 12:23pm
Starting a new topic thread for pics of my 67 SN I’m re-conditioning. Need to get to a PC for pic download soon. Testing
SN1648 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN1648 Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2019 at 12:34pm
Looking forward to pictures, im putting all new stringers and floor in my 69 SN.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2019 at 6:00pm
Daryn,
I too am looking forward to the pictures. Maybe you should start the new thread in the general forum section since the new section is for "What's new at CorrectCraftFan.com"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: March-27-2019 at 8:17pm
Good idea. I’ll figure this out someday. Usually I get kicked out of forums before I get this far
93/70 ccpb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93/70 ccpb Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2019 at 3:09pm
was that the light blue one for sale last year at a storage lot?if so glad someone is going to rescue it.
Alison View Drop Down
Admin Group
Admin Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alison Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 8:15pm
Posting pics for 67 ski nat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 9:49pm
Daryn,
Look'n great. Thanks for the pictures (and Alison). Has it been in the water yet? Did you remove the Carter YH's or did a PO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 10:17pm
Daryn,
It would appear to be a 318 Chrysler with the original but rebuilt Carter AFB based on this not too old post from 67ski nat
Originally posted by 67 ski nat 67 ski nat wrote:
10-4. At least he saved it from further environ damage. But I’m going thru everything with a fine comb, trying to take my time a make it correct. Only pistons will remain untouched   All new electrical wiring, exhaust, starter rebuilt, Sherwood d-60, original afb CARTER 3180, rebuilt. All old foam out, new floor. Gonna be a beauty
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 10:20pm
Ken,
Thanks for the proper ID on the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2019 at 10:27pm
Ken,
I think it's that funny shade of "Chrysler Blue" that confuses things
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2019 at 12:08am
Thank you very much Alison
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2019 at 12:17am
Glad you like. Yes Chrysler 318 smooth barely hear it running. , previous owner changed color with one new exhaust manifold. I see original green blue under pan. I painted motor mounts same as the other new Barr exhaust manifold I installed a Chrysler marine blue by moeller. Carter original Afb 3980s polished and rebuilt by Recarbco   Tested twice. Throttle hitting before clutch high rpm. Adjusted better now should engage clutch at idle.
Wish me luck next test soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2019 at 12:47am
John,
This may help. It's from the FAQ thread in the maintenance section.
Greg here is a how to post from Alan 81nautique,on how to adjust your cables---
There's a procedure to follow for properly adjusting your cables. Give these steps a try and you should be good to go.
1. Disconnect cables at trans and carb
2. At the morse control disconnect both cables and rotate the brass pin connector so there is approx 1/8" of thread showing at the cable end. Reconnect both cables to the morse.
3.At the transmission, place the transmission bracket(the one that the cable attached to) in neutral. You may have to move it back and forth to feel exactly where neutral is but it should detent in the center of travel. Once you find a firn neutral connect your trans cable.
4. Step 4 is the magic. Go back to the morse control and with the transmission engage button in, move the throttle lever to the forward engage detent. Just move it forward and it should lock into the forward position firmly, stop whne it does so. Now go to the carb, adjust the cable connector so the throttle cable smoothly attaches to the carb stud without moving the throttle. You are done.
This sequence works for me everytime with NO tweaking if you do it right.
The trick is you must have the throttle in the forward (or Reverse) detent BEFORE trying to attach the cable at the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: April-27-2019 at 10:59am
Pete thanks for thread on correct way to adjust cables. Will double check using this method. I may have accidentally backed into right action   CCfan is great support, invaluable
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 4:20pm
jpeg
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 4:25pm
http://www.correctcraftfan.com/forum/uploads/18449/4D849F97-25F2-4D06-A780-A3DCE7DD93F4.jpeg
I give up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 4:27pm
http://www.correctcraftfan.com/forum/uploads/18449/CF5210EE-8FCE-400B-AAA4-E12290D6C7AA.jpeg
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 4:31pm
Looks nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 5:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 6:43pm
Daryn,
Did the hull of your 67 have spray rails on it originally? They were wood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-20-2019 at 9:13pm
Daryn,
It sure looks like it did from when Daryn just bought it from cbr1000dude so somebody took them off
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 11:26am
Thanks desertskier for completing post from http. Yes had wood rails but screws and wood cracked poor seal. Spray Not to bad without but will replace this winter. Raised doghouse 3” with real glass mat for better clearance (no scoop), pearl white paint from Maaco. New custom rear seat for lucky passengers   New marine plywood poplar veneer floor looks clean and woody.   I’ll try couple more pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 11:38am
http://www.correctcraftfan.com/forum/uploads/18449/E6BD4314-6C7B-4D24-850E-29E6EEC558FF.jpeg
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 11:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 11:49am
Did it ever have a pylon ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 11:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 11:55am
Yes I have the oem pylon. But needs new side braces. Coming soon. I may go stainless
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 12:04pm
I see full http address on my end. How are you converting to image
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-21-2019 at 12:16pm
http://www.correctcraftfan.com/forum/uploads/18449/62F7FCC5-5FAA-42CC-BCBA-00BAE33AB685.jpeg
