79 Nautique |
Post Reply | Page <12345 6> |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Need a little help with floor. How thick is it? I tried converting but don't think it's right. I tried a piece of 5/8" and 3/4 " and the 3/4" seems to thick and the 5/8" not thick enough.
I know anyone should be able to figure it out |
John,
You'll notice there's a height difference in the main stringers forward of the engine. This is for a plywood base to give the seat brackets something to screw to. The difference should be 3/4". Aft of the ply, the sole would be glass over the foam if you are going back to foaming. Are you going foam or not? |
jterr
Is the floor 1 piece of plywood 3/4" and then another piece under that where the pylon goes between the stringers? And yes will be using the foam. Thanks JT |
Do you see the height difference in the stringers? That's where the ply goes. Then aft is the fiberglass over the foam. |
John,
Have you had the time to search out other stringer replacement threads. Some have some great pictures like this one I found: |
jterr
Thanks
Actually Pete original would have been 3/4" planks of various widths with glass over it.
There are reports of 1x's or ply. CC back then was very frugal and used what was on hand. I'd say the 1x's came from engine crating! |
jterr
Question of the hull decals. Been reading through some of the posts but most seem to be dead.
Any updates are places that might sell the templates/decals? |
jterr
Bought some Penetrating Epoxy; I thought I did. When I received and read the directions it says for poring in rotten wood not for brushing on.
jterr
Well still messing around with the 79-(83 has stringers just not in boat yet); thought I would remove those hideous graphics on the side and looks like they painted the side with something as I can actually scratch it off.
Any suggestions ...... |
John,
Clayton_1986 needs a copy of the stringers layout, are the ones I sent you available ? Here's his thread in the boat maintenance section maybe you can help him out http://correctcraftfan.com/forum/forum_posts.asp?TID=47613&PID=571774&title=1986-restoration#571774 |
jterr
I already sent him a email and soon as my slow a$$ boat guy gets done will send them.
He's been cutting them out for weeks but nothing in boat JT |
jterr
Quick question. What battery(Standard Type) are y'all using? I put 1 of the battery boxes out of my 83 in the 79 but the battery is too tall, lid won't fit????
jterr
Got new battery and all is well.
Next question. Where would one find that black rubber strip 1 1/2" wide that is on the big piece of wood behind the engine box(2 of them)? PO removed damn near everything original in this boat |
BoyceByerly
Newbie Joined: May-19-2015 Location: Durham, NC Status: Offline Points: 17 |
The two 'red things' are the in/out for the blower system.
Boyce Byerly
Owner of a '79 Mustang |
BoyceByerly
I have a '79 MUSTANG, which I know is different, but you didn't seem to be having much luck with the more specific query. -Boyce |
Boyce Byerly
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10653 |
I don't think you have that quite right They were called vents a couple times in the thread and that's what they are. Like you said in your vapor lock thread, one is the outlet vent for the blower but the other is also an outlet vent for air from the bilge area with no blower just a hose attached to it running down low in the bilge area behind the tank. The inlet to the bilge area is the front hood scoop, through some ducting to the bilge area up forward of the driver's feet under the front deck. |
jterr
No Problem. But I was thinking I redid a 79 back in the late 80's but it was a 76 that I did as a 79(graphics only); now I have a 79 that I'm just redoing till I get my 83 up and running. There that should clear it up |
jterr
You already asked that question yesterday JT Just so you have one answer.................beats me
jterr
Silly me I thought it might have been missed in the read
Thanks This might work??https://www.tools4flooring.com/johnsonite-cdxx-transition-p-484.html?gclid=Cj0KCQjwjYHpBRC4ARIsAI-3GkFKF8Q48-R8VkzpAuyIzZsWaFOMdaBK_V66rg-xMwxKbfyCXRd5C-0aAgezEALw_wcB |
jterr
Anyone can get a pic of the side ski holders? Thinking of adding to my boats while they are in pieces..
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=47654&title=nautique-ski-rack-out-of-93-sn |
jterr
Thanks this might be better and easier to make than that long section. |
jterr
Hey need some HELP ; I just tried to install new carpet and it looked good until I tried to glue it down. The sides where the hull curves in starting buckling out(would not lay flat).
I'm trying to put it down all in 1 piece, is that the problem????? |
Wisky Badger
Senior Member Joined: July-02-2015 Location: Wisconsin Status: Offline Points: 218 |
Let the Glue tac up and then install the carpet.
jterr
The problem I'm having is the carpet is bunching up (on the side where it curves back towards bow); no place for it to lay flat. Should I maybe just make a cut-don't really want a seam but if that is what it takes.
jterr
Started on the outside by taking off those hideous graphics. While removing also removed what looks to be paint.
I guess the PO painted the damn thing now not sure what to do I'll see if a photo will help show...... Suggestions |
