  New Posts New Posts RSS Feed - 1970 Skier Stringers and Engine restoration
andrewskiii180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewskiii180 Quote  Post ReplyReply Direct Link To This Post Topic: 1970 Skier Stringers and Engine restoration
    Posted: May-05-2019 at 1:37pm
Does anyone have plans/dimensions for the side panels used in early Mustangs/Skiers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2019 at 3:46pm
Andrew,
Your title says Skier but your question says Skier and Mustang. To my knoledge, the Mustang did have the hull side panels and the Skier did not. What model do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewskiii180 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2019 at 9:47pm
Mine is a 1970 Skier. I referenced mustangs because I figured if they did both have side panels that they would be the same..
I'm not 100% sure that my boat had side panels, but there are six or so holes in the inner side of the gunnels that are spaced in pairs(They line up like the images of side panels I've seen). I will try to send a pic of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewskiii180 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2019 at 10:30pm
If you look closely, you may be able to see the holes I'm referring to.
