Need fuel Injectors for 97 GT-40 |
BobinIL ![]() Newbie ![]() Joined: July-29-2018 Location: Illinois Status: Offline Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: May-10-2019 at 12:37pm |
I have been doing a search for a set of Fuel injectors for my 1997 Sport Nautique with a PCM Ford 351 GT-40. Would this be the correct ones?
https://www.summitracing.com/parts/fms-m-9593-lu24a/overview/ |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11196 |
The guy (manoseven) in the link says they worked for him
You'll have to look at the link in the second sentence of the first post to verify the same numbers link |
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3778 |
You might check the Ford Mustang forums, many of those guys upgrade injectors and will list brands and places to purchase them. There were millions of these systems in cars so the parts are actually common.
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5698 |
Yep I agree with the good advise already given whether the first link, second link, etc - 24lb injectors are the ticket and the aftermarket ones are much cheaper than the factory ford automotives- certainly cheaper than any that would be provided under the guise of "marine" parts.
gun-driver ![]() Grand Poobah ![]() Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4127 |
I bought a set of them here
https://www.fiveomotorsport.com/24lb-bosch-fuel-injector-0280150947-blue-top/ |
gt40KS ![]() Gold Member ![]() ![]() Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 946 |
Had mine rebuilt for about $15 each. Got a set of Bosch 24 lb from the net first (don't remember where) first that didn't work so well. They fit, and were 24 lb. but had some sort of 'upgraded' nozzle that seemed to do funky things. So I rebuilt instead and they've been working great since.
As far as the R & R question, short answer is yes. You will have to remove the plenum to get the job done. There really isn't much room under either the throttle body nor the plenum to get the fuel rail up & out of the way enough to remove the injectors. And by the looks of those, you'll likely need all the room you can get to pry those puppies out of there. Mine were about the same condition and almost assuredly had never been removed and were a nightmare to get out of their ports. And also yes, I would definitely replace the gasket. Good news is the plenum and throttle body + electronics will come out as a single unit by only removing the 7 bolts for the plenum - pretty easy. MAKE SURE you cover the exposed intake manifold ports after removing the plenum. Don't want to accidentally drop something in there! ![]() |
JCCI
1995 Ski Nautique GT40 |
