No spark or ign when turn on key |
skirunt
Senior Member Joined: January-18-2013 Location: Lexington nc Status: Offline Points: 115 |
Posted: June-29-2019 at 5:50pm |
I have got a lot of great help here during this rebuild. On to my last issue hopefully. I bumped motor to get dead center left key on. Changed alternator was lazy and did not disconnect battery until it sparked. Finished task reconnected battery no juice when I turn key. Jumped selenoid motor turns over as it should. With key on I have no spark. Battery is good. Any ideas would be appreciated. Thx
79 nautique 93 nautique
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10646 |
That spark was probably you shorting the alternator wire to ground and opening the 50 amp breaker on the back of the engine.
See the diagram below It might be hidden under a cover but the red reset button should be sticking through a hole in the cover, depress the red button and then try starting the engine. There's also the 20 amp ignition breaker on the dash that you could reset but the 50 is probably the culprit. |
skirunt
Thxs Keno, I hit the 50 amp in back, it clicked but no juice, the 25 under dash I looked at but did not see any reset on it.. Thx
Did you give it time to cool off before resetting? Also sometimes when they're old they open once and never close again. If you have a multimeter check for battery voltage on both the in and out connections on the breaker. Do the same voltage check at the 20 amp breaker too. |
