Distributor Springs Advice |
Post Reply | Page <12 |
davidg
Thanks Ken! I may go back up today and continue working on it to try and dial it in.
My manual on page 9 looks completely different than the reference guide from this site. It does not have all the info regarding the different distributors, and timing difference. As it relates to my idle, when I drop it in to gear, it seems like it drops down quite a bit. I will try to get specifics numbers, but, it seems like around 300-400 rpm. Gonna take the dwell meter with me today to put that in the mix to see how close I am using .018 as the gap on the points. |
Sounds like you are almost dialed in. When working with points try and carry an old fashioned paper business card, white without the new style plastic face. The thick white paper works really well to swipe through your points. Open the points install the card, release the points so pressure is now on the card and it is between the points.
Drag the paper through the points. Ususlly you can only get about a 1/2" drag due to space limitations. Now with the card removed look at it. The white paper will drag out any dirt or grease that landed in your points. Even on new points install I have seen this trick pull out dirt or grease and fix points issues. It will not fix glazed over points. If the points are good and clean you will see a clean drag mark on the card. This is a 15 second check and lets you know the points are clean. An old mechanic showed me this trick 40 years ago and it still works today if you have the old style paper business card on hand. I suspect many points issues are caused by less than clean feeler gauges when setting the gaps. |
davidg
Field Report #2......Success!
Points Cleaning: Not wanting to make too many changes at one time so I could tell what actually fixed things, I left the NAPA spring in the dizzy. As Mark suggested above, I dragged a piece of an ACE Hardware brown paper bag through the points to clean them. I learned this trick late in life (as in last week) when the boat wouldn't start. I had sprayed PB Blaster on the timing advance weights. Apparently some got on the points and it wouldn't start. My marina guy grabs a piece of an ACE paper bag, drags it through the points a couple of time, and wallah......it fired right up. The PB Blaster and points apparently don't work and play well together. Points Gap: Yesterday, I inadvertently took the points off the dizzy plate, and screwed up the adjustment. Re-gapped them today to .018". Timing: I confirmed I was at 10 BTC. Also watched the timing mark go up toward 25ish or so at 3,000 rpm. So, the advance is working properly. Result: Headed out from the dock to open waters, and brought the rpm's up to 2500 or so. No stumbling, no missing. Ran like a pup! Dwell: I checked the dwell once everything else was pretty much dialed in. The spec calls for 29-33. I was at 25. I assume the only way to change the dwell is to change the points gap, correct? If so, to increase the dwell, do you decrease or increase the point gap? Hillman #119 Spring: I wanted to see if the boat would even run with the NAPA spring, and it did. I am not sure it's optimal, but, I feel a lot better today, than I did yesterday at this time. Next time up, I would like to throw the #119 in to see if I can feel a difference. I will say that with the NAPA spring, the acceleration is okay. It certainly wasn't a rocket sled. Hopefully the lighter spring will put a little hitch in the giddy-up. Overall, I am pretty satisfied with how its running now. I sure do appreciate all the input and advice you guys gave. However, I am still a little concerned with the quality of the idle. Tends to range from 600 in gear at idle, to 1100 in neutral.. So, I am going to research the finer points of tuning the 4160 carb. Other than the idle screw, the only other way to adjust it I could see was two very small screws (one on each side of the carb metering plate). I assume one, or both, or to adjust the idle circuit. |
Glad you made progress, it is amazing how much help a quick swipe of paper through the points can offer.
As far as your swing in RPM in gear and at idle in neutral, 600 in gear to 1100 in neutral. That indicates a weak idle to me. It can be very lean and do this or too much timing at idle. With my old 78 351W with a Holley I found if I opened the two side fuel meter screws a half turn more each side it improved my idle quality in gear, made it stronger. If you go too far it will start to smell rich at idle. This also seemed to help with starting the engine without needing to give it throttle. This advice assumes the rest is working well already. Did you verify all 8 plugs are still firing? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10662 |
Reducing the gap will increase the dwell The 2 screws each feed the idle circuit for their associated primary venturis. They both get adjusted together Shoot for best vacuum idling in gear 1 1/2 turns out is the "usual" starting point and turning out richens the idle mix on your marine 4160 The idle circuits could also need cleaning. Best way is to remove the primary metering block and then soaking and blowing out the passages with air. An ultrasonic cleaner works good for the soaking if you happen to have one |
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Online Points: 936 |
While you all are in this topic of metering blocks. Can I take off just the metering block and leave the carb on the boat? I want to clean and blow out. Just developed a rough idle but she runs great otherwise! Will I ruin stuff in the metering block (ie need to rebuild anyway)?
It might be less trouble overall to just take the carburetor off then do things on the workbench especially if you have a metal fuel line.
Getting that sprung to get it off and back on can be "not a lot of fun" especially if you cross thread the fittings. If you have the non stick reusable gaskets in there now, it should come apart easily. You have to watch out for the O rings on the accelerator pump transfer tube that goes between the metering block and the body and also the O rings on the transfer tube between the primary and secondary bowls. (Older carburetors don't have the accelerator pump transfer tube, their body and metering block and the gasket between them are different with a drilled passage instead of the tube) Having a carburetor kit on hand is always a good thing in case you run into problems. Also if it's on the bench, getting the accelerator pump linkage together right is easier. But..............it can be done on the boat. Something I learned from a chef who also worked on carburetors, if you spray the gaskets with some PAM or whatever your favorite cooking spray is before assembly, they.ll come off easier the next time. Even the non stick gaskets like a shot of PAM |
davidg
Ken.....Does it matter where you take a vacuum reading from? I already have a port on the back of the manifold. I also got one of those Dorman kits to get to right size hose(s) and fittings to get it to work with my gauge. I saw in one of your posts that you measure the vacuum from the PCV hose with a T set up. I assume either locations works!?
By the way, the needle on my gauge is very "twitchy". It stays in one area, but, very "fluttery". What is that a sign of? The face of my gauge didn't have anything for that. |
davidg
By the way, speaking of my manifold, while I was looking around under the hood, I noticed something interesting, or concerning actually. On one of the runners of the manifold directly under the carb, I noticed that there appeared to be a crack on a sharp edge. I am not sure if its just paint separating, or if its actually a crack, and possibly a vacuum leak. You guys ever seen anything like this on your engines? If it is a crack, it looks like a little epoxy mix (I forget the name of the famous stuff) may plug it up. I couldn't feel any suction when I put my finger over it with engine running.
What you show for getting your vacuum readings works Dave.
I'd vote for peeling paint but if you scrape it a little, it might tell you more. Spray a little carb cleaner or even just some soapy water there while the engine is running and see if anything changes Oh, almost forgot, that famous stuff must be Pete's favorite epoxy, JB Weld Nice skinned knuckle by the way |
I'd look at one of the vacuum reading charts on line to see if you find a description of your twitch and what the variation is between the high and low readings.
