3rd starter issue: Sport 98 GT40 EFI |
rakerdeal
Groupie Joined: January-10-2018 Location: Lexington, NC Status: Offline Points: 92 |
Posted: June-30-2019 at 8:42pm |
So last year it was the fuel pump relay...this year most likely the solonoid...
The boat has been starting great for a few days, just barely turning the starter and the boat is running! Then after one person was finished tubing, we shut down for another to wakeboard and when we hit the key all we get is terrible sounding grinding! I pulled the starter again. The starter teeth/pinion gear teeth obviously are ground down some and the casing around the shaft is damaged (photo). We inspected the crankshaft/flywheel ring gear and it looks fine. Any ideas? |
CYS
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10645 |
There's a bushing at the very end of the nose piece that may be worn. Some have a needle bearing instead of a bushing but they wear out too.
That lets the shaft move radially when it shouldn't (when the gears are trying to mesh) and leads to grinding like you describe. You can buy a new bushing and replace the old one Or it could be corrosion on the shaft which prevented the pinion gear from fully extending outward on the shaft Since you didn't say anything about loose mounting bolts letting the starter move around, we'll assume that wasn't the problem . Myself, I'd say 3 strikes,,,,,,,you're outta there, buy a new starter like mentioned in your other thread and then take this one and let the kid tear into it, do some learning and maybe you'll have a decent spare. with a little work and some parts Those spare parts come in handy at times like this |
rakerdeal
KENO new starter will be bought. Loose bolts? Well, that was the first thing Pax and I checked and they were soundly tight. Ha! Here we go.
It was interesting though how the boat started after replacing that solonoid. I have never had a boat start as quick as that thing was firing up before the grinding episode! |
CYS
Normal CCW rotation GT40 engine, use an Arco 70200 CW rotating starter or anything that cross references to that.
Here's a link to make sure you get the correct rotation starter in case you're confused link |
Pax can have some fun with the old one.
The hardest part of reassembly is putting the brushes over the commutator . You can find write ups with pictures on the internet |
Charles, I'd say the old start relay had some burnt contacts that didn't allow the full voltage to get to the starter. Bad contacts can be caused by several things but what's common is bad cable connections at the battery, bad and or undersized cables, a bad and or low charged battery or even a deep cycle battery. Many times the contacts in the relay will actually weld together keeping power running to the starter. |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2840 |
The boat, engine and starter were protesting TUBING. My boat is allergic to tubes and simply refuses to leave the marina with a tube on board. Just saying.... |
