  New Posts New Posts RSS Feed - Throttle Connector
Throttle Connector
dgabler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgabler Quote  Post ReplyReply Direct Link To This Post Topic: Throttle Connector
    Posted: July-03-2019 at 9:07pm
Just a friendly note to check those throttle connectors :) Looking at lubricating my cable and discovered that there was a bit of wear on my connector.
After investigation the cause of the wear was due to some metal on metal friction due to the rubber dust protectors failing. Easy enough to fix if you have the parts on hand.
Natique Parts[
Skidim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2019 at 9:22pm
David,
Have I missed something? Where are these rubber dust protectors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgabler Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2019 at 9:30pm
The dust protectors are on the morse/teleflex cable.   The dust protectors failing caused metal on metal wear for the threaded shaft, which in turn caused the brass to wear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2019 at 9:35pm
David,
Ok, I can see where an older control cable will cause a higher load on the brass cable connector but ALL the connectors wear in time no matter what the cable condition is. I thought there was some kind of new rubber boot over the brass connector.
