  New Posts New Posts RSS Feed - Help on Upgrading Electrical System
bfootr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Topic: Help on Upgrading Electrical System
    Posted: July-08-2019 at 12:25am
Hi - Looking to upgrade the electrical system on my 89' SN. Going to add a second battery and this Blue Sea Systems Add-A-Battery-Kit which includes a true battery isolating switch and an Automatic Charging Relay (ACR). Also, considering an upgrade to a 105 amp alternator versus the original 50 amp one. Doing all of this to provide better and more reliable power for accessories (including a future stereo and amp) while keeping the start battery isolated and always ready to start the engine.   A few questions please.
Any experience or tips to share out there with this or a similar set-up?
Best location for the second battery?
With the increased amperage available from the alternator, what wire(s) and to what AWG do I need to change to?
Any other considerations?
Thanks in advance for the assist. Great to be able to leverage the expertise on this forum! -Gene
baitkiller View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2019 at 10:23am
Start here.
https://www.paneltronics.com/atimo_s/news/E11Excerpts.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2019 at 8:20pm
Could anyone tell me which wire(s) need to be a larger gauge if I upgrade the alternator to 105 amps? Thanks.
Orlando76 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2019 at 8:36pm
Not to be a jerk but you’re adding extra weight and headaches. We see this all the time, sigh.
1) upgrade hot and neutral going to dash
2) frequently check and clean battery connections
3) small and powerful yet compact jump boxes are the way to go these days
4) a decent Bluetooth radio such as the Altec Lifejacket are way more compact, zero impact to an intact boat, less pieces to troubleshoot, sound almost as good as the average good real radio, and last 18+ hours on a charge
Spend more time boating and less time working on the boat. A quality, well charged, bci 24,65 etc will last for hours even with a radio going.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2019 at 9:03pm
Thanks Todd. You’ve given me some worthwhile considerations. Will revisit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2019 at 9:06pm
William,
Why the dual batteries? Tell us more. I happen to agree with Todd.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2019 at 10:22pm
Was planning on putting in a stereo, amp, 4 speakers, and a sub and liked the idea of an accessory battery being completely isolated from the starting battery. Thought that the battery switch and ACR were a good solution for such a setup. However, I am rethinking due to the added weight and placement of the second battery. .
Post Options Post Options   Thanks (0) Thanks(0)   Quote bfootr Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 1:41pm
Closing the loop on this. I took the advice here and kept to one battery. Instead, ordered a Bluetooth speaker (JBL charge 4) and already had a small portable jump starter (NOCO 1000 amp) which I’ll use as a backup. Appreciate the advice!
zwoobah View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 1:58pm
Bluetooth speaker is certainly easier. You can wire in a 12v ignition-switched USB charger plug for it - so it will recharge the speaker when you are running the boat, but won't drain the boat's battery when you are anchored and playing music.
1968 Mustang 16 - 351W powered
desertskier View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 2:25pm
When I rewired my dash I added these:
Blue Sea USB port
91NaughtyQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 5:03pm
I like those. I mounted a small dual USB/12V charger under the dash, but you have to be a yoga expert to get to it. Gonna install these. Any gotchas to watch out for drilling the dash and leather parts?
Gary
1991 Ski Nautique
(Previous)1984 Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 5:08pm
I was a little worried I was going to rip the dash. I used a hole saw and went very slowly. It cut through without any tearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2019 at 5:16pm
Great thanks.
1991 Ski Nautique
