  New Posts New Posts RSS Feed - Procedure for setting idle on GT40
workky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Topic: Procedure for setting idle on GT40
    Posted: August-01-2019 at 12:33am
Anyone know the proper procedure to set the idle speed on the gt40?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2019 at 11:03am
Could not find any reference to setting idle in any marine manual. But many times 5.0 Mustang guys have already done the work. Here is the procedure from the LMR web site might be worth a try-
From Ford Performance: 1986-1995 Mustang Idle Setting Procedure
Please Note: These steps MUST be performed in sequence!!
1- Get engine to operating temperature.
2- Disconnect IAC (Idle Air Control) Solenoid. If engine stalls, turn throttle-stop screw in one full turn and restart. Repeat as necessary until engine will idle with IAC unplugged.
3- Set idle using throttle stop. Idle speed will vary depending upon modifications made to the engine. Set to where you are comfortable with idle speed.
4- Set TPS (Throttle Position Sensor) anywhere from .96 to .98 volts. This is done by loosening the mounting screws, and lightly rotating TPS. If you cannot obtain the desired range, you may need to make the mounting holes slightly larger. This can be done by drilling them.
5- TPS wire colors to be probed are generally BLACK and GREEN wire or the GRAY/RED and GRAY/WHITE, depending on your vehicle.
6- Stop engine. Disconnect negative terminal battery cable for 15-20 minutes. You may wish to tap the brakes or turn the headlights on and off a few times as this will help to ensure that you have purged any remaining electrical current from the vehicle.
7- Reconnect IAC Solenoid
8- Reconnect battery cable to the negative terminal
9- Restart engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote workky Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2019 at 1:28pm
Thanks Gary, much appreciated.
Had a moron who used the boat last week turn the screw becauae he thought he needed to speed it up..
Canuck-Surfer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Canuck-Surfer Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2020 at 1:04pm
I took apart the TPS sensor yesterday not knowing it needs to be set so exactly. I also played around with the idle stop screw under the throttle body. So I am going to follow these instructions today. Does anyone know where exactly to place multimeter leads to test TPS voltage? If I recall, the loom is pretty sealed there....
Gary/Keno??
1996 Sport Nautique GT40 EFI
