what's up with my rudder?? |
Author | ||
flyweed
Gold Member Joined: July-11-2016 Location: WI Status: Offline Points: 539 |
Posted: August-04-2019 at 11:03pm |
Hey guys,
Noticed THIS happening to the leading edge of my rudder. What the heck is going on? DO I need to replace it?? Any comments welcome. Thanks |
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3588 |
I am pretty sure that is the result of cavitation affecting your rudder.
With that said a buddy had his Malibu Skier docked at his dads dock on the Sacramento River for a year. He went down to use it and the battery was dead so he ran a cord down to the dock and hooked up a batter charger. He left it for a couple weeks hooked up and in the river current. The battery charger somehow caused electrolisis and it ate at his rudder, Prop and Fins. He had to replace them. I never got to see the bad parts but he told us the story. If your rudder looks like this what does your prop and fins look like? |
Yes, cavitation corrosion. The same phenomenon that can happen with any underwater gear just like a prop we just discussed in this thread.
Orlando76
Damn that’s heavy. How deep is the pitting?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10638 |
Take a look back at this thread in the link down below from about a month ago.
You were obviously so hell bent on lapping your shaft and new prop that you didn't pay any attention to that rudder that was right in front of you Or it wasn't nearly as bad a month ago and didn't catch your attention First picture in the thread, there is some damage before the Acme went on but it's hard to tell how much One picture later on in the thread shows the other side of the rudder in good condition I guess only you know how much difference there has been in a month or so link |
flyweed
MrMcD - yeah, it wouldn't be electrolysis. I have noticed very small pitting starting over the course of the last several seasons. I very rarely put my boat on a charger during the season anyway. I have definitely notice this get MUCH worse since I changed out the props just a few short weeks ago. My Fins are nice and smooth, and my prop is shiny new. |
So whatcha gonna do about it?
You put a new prop on and the erosion got a lot worse with the Acme. I'd be getting it repaired or at least doing a temporary repair with some epoxy and keeping an eye on it. The Acme blades are probably a fair amount closer to your rudder than the original prop blades were. |
flyweed
Yeah Ken...I think I"ll REPLACE the rudder next spring, for the remainder of this season, I'd just like to repair it. For a temporary repair with Epoxy, do you have a "how to" or any advice? Or is it as simple as mixing up a two part epoxy, and filling in the "cavitation" and then smoothing to match surface??
FLCaptain
Groupie Joined: February-10-2019 Location: Orlando Status: Offline Points: 45 |
Yes. You can even use something as simple as jb weld. You need some build up and expectation of tear down. If you're gonna run 10 hours a week or so then you’ll probably be fine not replacing the router and just building it up with an epoxy resin like a JB Weld or similar. In the meantime order yourself a new rudder and then look under your hull and figure out what’s causing that kind of suction cavitation.
Thanks(1)
Dan,
I've had very good results repairing cavitation worn pump volutes and casings with epoxies. I remember one pump I needed to repair every 6 months because the pipe fitter made the classic mistake of installing an elbow within 12 times the pipe diameter to the suction side of the pump causing the cavitation. Devcon has been around for many years and is my preferred |
If you were to take a picture at the same angle as the one below showing prop blade to rudder distance, prop to strut distance and prop blade to hull clearance, it might be helpful as far as determining why the erosion is so bad
Take the picture with one blade tip at it's closest point to the rudder just like the picture shown In a previous thread about your prop nuts, somebody thought you had a replacement prop shaft and maybe the length is different than the original. |
MrMcD
Ken, I was thinking the picture above looked like the prop was pretty close to the rudder.
Went down and took a picture of my prop on the 95 Nautique. Distance looks the same but I note I should have used stainless set screws on the cutlass. My set screws show rust already. The battery charger electrolisis I understand would not happen in standing water but in the ruver current the moving water creates the effect that ate away at my buddies Malibu parts. I was told many boats that sit in the river have had this happen if they hook up battery tenders or chargers. I am sure someone understands why. |
Mark,
Since you've brought up electrolysis a couple times and. just so everyone knows, It is not the same erosion that happens with cavitation corrosion. |
The picture I put up was from Aussienorts a handful of years ago Your picture and that one should give him something good to compare to. Electrolysis removes unwanted, unsightly hair right Pete? |
MrMcD
The damage on that Rudder is impressive. I hope we find out why it is happening for the OP and the rest of us to learn and avoid.
flyweed
Well, I can pretty much tell you HOW it happened.....1. the rudder is Original to the boat..so it's OLD, and it did have some slight cavitation happening in those spots over the last couple of years. 2. I replace the Original 4 blade OJ prop, with a new 3 blade 540 Acme prop.
That's ALL that's been changed. I will do measurements of prop to rudder, etc when I get back up north to our place. The boats up there. |
MrMcD
Your rudder is only 2 years older than mine which is in the pics above.
Something is off. Sorry, I forgot the obvious, you may have 2,000 more hours use on yours, mine is young. |
flyweed
yeah...my rudder (and boat) is pushing the 2400 hour mark. Still runs like a champ. I did JB weld in those spots and it seems to be holding up well. Will replace rudder either later this fall, before I winterize, or next spring.
Netdewt
Senior Member Joined: February-15-2010 Location: Minneapolis Status: Offline Points: 215 |
What is cavitation, and what causes it?
1989 Ski Nautique 2001, 880 hours
Netdewt
My Acme prop sings at low speeds after being rebuilt. Hope I’m not wrecking anything my using a rebuild...
