Coil part number |
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 403 |
Posted: August-10-2019 at 3:53pm |
Searched to no avail. Called parts store and not right coil for my application. No number on my coil. Does anyone know the coil part number for a 1988 - 351 W ? I am going to take mine with me for reference but tired of deer in the head light eyes that I get .
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10643 |
From Advance Auto, a BWD E70 coil fits the bill.
1.5 ohms on my meter If you're a Speed perks member and you dig up a 20% discount coupon, it'll be under 20 bucks otherwise about 25 bucks. Or ask wherever you go , for a coil for a 1967 Ford Mustang with a 289. 2 wheel drive if the parts guy absolutely needs to know This will work for points or most electronic conversions |
Faceplant
Ok, Thank you. Just out of curiosity , why do the auto parts store try to sell the wrong one when you tell them that it is a 351. Were our engines changed for marine use and different coils used ?
Don't know what they're giving for part numbers or coils ,but you only need a coil of about 1.5 ohms primary resistance, secondary resistance will be in the 8 to 10,000 range and it'll say "for use with external resistor"
If you told them it was for a 1969 Mustang with a 351 you'd get the same coil |
Faceplant
I will tell them that in the future
Faceplant
Purchased electronic parts and they turned out to be wrong again. Just to re verify, aren't all of our electronic parts are supposed to be the same as a 1967 289 ? Also , would the fuel pump be the same also ?
Faceplant
I previously purchased points and condenser that don't fit. Called Advance and asked for part numbers for a cap, rotor, points, and condenser for a 1969 351 . I then called another store and asked for the same part numbers for a 1967 289 . The condenser and points both came back with the exact same part numbers but the part numbers are the same as the ones that I previously purchased that don't fit. . I am now thinking that previous owners might have changed the distributor and that is why these parts don't match up. Plausible ? I am not sure if cap and rotor are wrong also but figure that these will be wrong also. I really don't want to take plug wires off of cap(to take for reference) until I have the new one side by side . I tend to REALLY screw things up . Easy peasy
The only ignition part that really interchanges is the coil that you originally asked about. Ford used their own distributor in a 67 Mustang and your 351 PCM uses a Prestolite marine distributor so points, rotor, cap, condenser are different. A 351W marine engine is kinda a mongrel I'll post some numbers for finding points etc at a local auto parts place in a little while. |
Faceplant
Oh. Now I see . I would appreciate it .
Here are some Sierra numbers for ignition parts for your 88 which should be the screw down cap distributor. These numbers work for getting parts from NAPA with a NAPA label on them.
Points 18-5303 Condenser 18-5347 Rotor 18-5403 Cap 18-5352 The older clip down cap uses the same points and condenser but the cap and rotor are different. Here are part numbers for the cap and rotor for the clip down cap Cap 18-5369 . Rotor 18-5407 They'll also sell you a coil for either distributor, same coil for both and the part number is 18-5435 but it's a little (Ok a lot) pricier than the coil mentioned earlier in this thread. It's the package that says "marine" that magically jacks up the price. You could also get parts or a kit from SkiDim, NautiqueParts or a variety of other marine outfits |
Faceplant
Thank you for the numbers. Kicking it around to get existing distributer rebuilt or maybe change to HEI system.
Jeff,
Not all of us go with the "upgrades" on ignition systems. I for one am fine with running point sets in my 54 and 64. Yes, they do require an occasional replacement but I've also gone so many years on one point set I can't even remember the number of years! EI conversions have improved over the years as many were unreliable in the early years and occasionally there still are failures. Rebuilding a distributor basically involves cleaning up the shaft and installing new bushings. |
That barely qualifies as a fluff and buff Pete He's got to check the slots in the advance limiter plate for wear that cause sticking, check the flyweights and the pins they pivot on for wear, find new springs if they're broken. stretched etc. All of those parts fit into that category called "no longer available" unless he buys a NOS Prestolite on EBAY and in his puts his old gear on the NOS one.. |
Jeff,
If you do decide on rebuilding your distributor and don't what to take on the job yourself, I recommend a professional rebuilder. Here's an interesting article by Hagerty. In it is a link to Advance Distributors who comes recommended especially on vintage distributors. Note he has thousands of springs rather than using some spring from the hardware store. Then, he has the Sun distributor tester as a final test to check the advance curve. |
I had Jeff do the distributor on my old MG, he does beautiful work. He is well known in British car circles.
You should send your Tique distributor to him to have that electronic gadgetry removed and converted back to points Pete. I seem to think you have the parts to do it Or have them electronics been nice and reliable for the last 12 years and however many years they were installed before you bought the boat with that module cleverly hidden under the cap unknown to you? |
Faceplant
I will have to think about pros and cons .. Upon reading more , if I do end up rebuilding my existing distributor, I will send it out to link above that Pete recommended. On a different thread, someone said that if you install a HEI that you need special wires and plugs as well ? Is this true ?
