  New Posts New Posts RSS Feed - Petit paint on wood deck
Thomasn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Topic: Petit paint on wood deck
    Posted: August-19-2019 at 12:39pm
Ok, we got the deck sanded down to bare wood and I want to use petit paint to use on a part of the deck and stern. My question is, should I put a sealer on the wood before I paint it, and will the paint stick to a spot on the hull that is now finished with varnish? This is for a small stripe on the upper hull. I am figuring on bleeching the rest of the deck before staining and seealer and varnish (verafane), all petit products.
Thanks
Thomasn
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2019 at 8:05am
Thomas,
Is this for the boot stripe? I've used plenty of Petit EZ Poxy and have always been very happy with it. I have sprayed it and also used the roll and tip method both with great results. On the bare wood areas, I suggest using Petit EZ Prime first. If open grain needs filling, then several coats and sanding's will be needed. On other coated areas like varnish, make sure it's sound (no peeling or checking) and just give it a light sanding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2019 at 10:52am
Yes it is for the boot stripe. And, thank s, again as usual you have answers for me..
TF
Thomasn
