Impeller lost chunks. No thermostat to stop chunks |
Author | ||||
Evilsizer
Groupie Joined: August-29-2019 Location: Ohio Status: Offline Points: 62 |
Posted: September-04-2019 at 11:16am |
Hey guys. Just purchased the boat. A 78 Ski Nautique with the 351. My impeller is missing chunks. I checked the thermostat housing and found no thermostat was installed. Does this mean a total rebuild?
Andrew,
Rebuild of what? The RWP or are you thinking engine? Unless the engine was overheated and run for some time, I would say no. Keep an eye for signs of water in the oil. If you are thinking the RWP, then no. Just get a new impeller in it. A T stat would help too! |
The Thermostat lets water out, not in
Check the status housing water inlet, it's inside dimensions are quite small And check the exhaust manifold inlets |
Evilsizer
Ok. I was thinking the chunks would have went down the intake and into the motor
Orlando76
well actually it does both. |
bfootr
Senior Member Joined: March-04-2019 Location: Benson, NC Status: Offline Points: 138 |
Don’t forget to check the water pump IINLET hose. When my impeller broke apart, I found the broken vanes there. Most folks including myself initially check downstream from the water pump. Often the broken vanes obstruct the water inlet side.
No |
I'm going with out! |
Orlando76
It’s gotta let it in to let it out. It doesn’t magically produce water. |
Do you eat with the same hole you ***************?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10667 |
Sometimes I have my head up there though,as a matter of fact I think we all have at one time or another |
huh, seems my careless brevity caused some seasons-closing consternations...
Permit me to rephrase... Water exits the engine block through the tstat Its presence could only trap pieces exiting the block, but impeller chunks would rather plug inlets , then if get through skip the block entirely and go out the manifolds, as that is where the major flow and delta-p is. in summary, Its a gazouta, not a gazinta |
96SNEFI
Senior Member Joined: March-23-2009 Location: Canada Status: Offline Points: 138 |
So thinking about this in the fuel lines...there are little screens here and there in the fuel path.
Could there be a way to screen the pipe from the RWP exit before it "gazinta" the engine thereby capturing the chunks? |
