  New Posts New Posts RSS Feed - 61 Intercepter water pump
Thomasn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Topic: 61 Intercepter water pump
    Posted: September-09-2019 at 8:26pm
Looks like I need a rebuildable or usable water pump for my 61 CC 100 hp intercepter. I had a guy pull mine apart and he damaged the housing and shaft so here I am with a new inpeller and seals and bad housing.
Jabsco 8470 pump.
Thanks
Thomasn
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2019 at 9:40pm
Thomas,
What's the extent of the damage to the housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Posted: September-09-2019 at 10:49pm
The guy who took it apart, evidently beat the shaft out of the housing to get the impeller out. That in turn damaged a bearing? or something like a pressed bushing that the shaft went thru to the housing. It actually looked like some tiny wound springs that the shaft fit into.
I am kinda talking about something I really dont know about here, but maybe in the AM I can go down to the repair shop and try for a picture.
Thanks Pete,
TF
Thomasn
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 7:05am
Thomas,
From your previous post:
Thomas,
Where have you been looking for parts? The impeller or other parts? If bearings and seals they are generic and can be found at a power transmission distributor (bearing house)
Guide to Jabsco impellers
all Jabsco rubber impeller pump service parts
8470 parts list
Originally posted by Thomasn Thomasn wrote:
Thanks Pete, I ordered everything I needed from Jamestown Distributers.
Thanks again,
TF
So, you got the parts and then your "mechanic" went at the pump with a hammer?    Bearings, bushings and seals can be replaced. The discontinued housing would be the problem. Take a good look at the pump, get back to us and then please, find someone without the hammer!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 9:08am
Yea, that's what I did, new guy has been working on boats all his life. I think he will try to save it, but has some doubts.
Thanks,
Thomasn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 9:09am
Jim Harris at The Engine Room in South Portland Maine can likely rebuild the pump for you or sell you a rebuilt one. 207-252-0996.
He rebuilt a 100 hp Interceptor not too long ago.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 9:14am
Thanks,
What doubts?
Thomas,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 9:45am
I did call Jim Harris just now and left a message..
Thank you.
Thomasn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 10:16am
Thank you.
He did call me back and I am confident he will solve my entire dilema. Great guy to talk to.
Thanks again,
Thomasn
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 10:21am
Thank you.
Thanks again,
And Jim uses a hammer to drive nails!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thomasn Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2019 at 10:30am
Thank you.
Thanks again,
Point Made
Thanks again,
Thomasn
Copyright 2020 | Bagley Productions, LLC
