Winterizing |
Stuckers Nautique ![]() Newbie ![]() Joined: September-08-2019 Location: Devils lake MI Status: Offline Points: 30 |
![]() ![]() ![]() ![]() ![]() Posted: September-11-2019 at 11:47pm |
What is the best thing to use in the winter to keep the animals out of the boat when stored outside.
tryathlete ![]() Platinum Member ![]() ![]() Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1799 |
I like a shotgun. Joking aside, does anyone tape their exhaust flaps or so anything beyond shrink wrap and such?
Ok thanks I have bread that Irish spring soap will work or moth balls.
Mike, I tried the "wives tails" methods and didn't have good results so I went with the dried coyote urine designed for the job. I put about a 1/4 cup in old nylon stockings and hang a couple in the boat and a couple under the trailer. |
Thanks
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
And in the spring you get the fresh, clean smell of coyote urine when you pull pack the cover. At least there won't be any squirrel poop...
JQ |
JQ, You've used it? Funny, I've used it for years and NEVER had an odor issue. If you have, did you use the Shake Away brand I posted the picture of? |
