  New Posts New Posts RSS Feed - #2 trailer jack wheel asbly.
1969cc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1969cc Quote  Post ReplyReply Direct Link To This Post Topic: #2 trailer jack wheel asbly.
    Posted: September-13-2019 at 7:27pm
Lost #2 trailer jack wheel asbly. Any one have one?
If you see light at the end of the tunnel you might be looking the wrong way
69 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2019 at 7:38pm
Fred,
Anyone who had one, probably lost theirs too! So, take a look a Etrailer. . The diameter of the down tube will be the critical dimension.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-13-2019 at 7:47pm
Check with Marty.Several years ago he was able to find the complete assembly, He might be able to tell you where to get a wheel. I think this is his current email- mtmabe@northstate.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2019 at 4:39pm
I made one for my old boat, I purchased a nice swivel wheel and it had a friction brake which came in handy. Welded a small pipe stub that was sized to slip inside the trailer Jack to the attachment plate and drilled a hole for the wheel lock pin. It worked perfect till I sold that boat. It was removeable as needed. It was much better quality than the original allowing me to roll the trailer around with a lot less effort but to keep it from rolling after parking I had to block the boat tires or apply the friction brake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2019 at 4:43pm
Similar to the one I used to make a new one.
https://www.amazon.com/Swivel-Caster-Wheels-Lockable-Bearing/dp/B01MQ0JY25/ref=sr_1_9?keywords=swivel+wheels&qid=1568572785&s=gateway&sr=8-9
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1969cc Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2019 at 5:19pm
Thanks for the replies. Gives me an idea what I have to do.
69 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2019 at 6:50pm
Here is what Marty came up for us with when he was researching them. It is an Attwood the shaft is 1 3/4 and the wheel is 1000 lb rating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1969cc Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2019 at 10:16pm
That Atwood looks pretty good. I'll do some searching.
69 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1969cc Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2019 at 7:56pm
I ordered a similar one. I am making a bracket to bolt it on.
Thanks for the help.
69 Mustang
