#2 trailer jack wheel asbly. |
1969cc
Groupie Joined: February-22-2005 Location: United States Status: Offline Points: 84 |
Posted: September-13-2019 at 7:27pm |
Lost #2 trailer jack wheel asbly. Any one have one?
Fred,
Anyone who had one, probably lost theirs too! So, take a look a Etrailer. . The diameter of the down tube will be the critical dimension. |
Check with Marty.Several years ago he was able to find the complete assembly, He might be able to tell you where to get a wheel. I think this is his current email- mtmabe@northstate.net
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3589 |
I made one for my old boat, I purchased a nice swivel wheel and it had a friction brake which came in handy. Welded a small pipe stub that was sized to slip inside the trailer Jack to the attachment plate and drilled a hole for the wheel lock pin. It worked perfect till I sold that boat. It was removeable as needed. It was much better quality than the original allowing me to roll the trailer around with a lot less effort but to keep it from rolling after parking I had to block the boat tires or apply the friction brake.
MrMcD
Similar to the one I used to make a new one.
https://www.amazon.com/Swivel-Caster-Wheels-Lockable-Bearing/dp/B01MQ0JY25/ref=sr_1_9?keywords=swivel+wheels&qid=1568572785&s=gateway&sr=8-9 |
1969cc
Thanks for the replies. Gives me an idea what I have to do.
Here is what Marty came up for us with when he was researching them. It is an Attwood the shaft is 1 3/4 and the wheel is 1000 lb rating.
1969cc
That Atwood looks pretty good. I'll do some searching.
1969cc
I ordered a similar one. I am making a bracket to bolt it on.
Thanks for the help. |
