  New Posts New Posts RSS Feed - Ignition button powers up dash
Jay_L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay_L Quote  Post ReplyReply Direct Link To This Post Topic: Ignition button powers up dash
    Posted: October-18-2019 at 2:23am
I just got a 1987 Ski Nautique 2001
When I turn the key to the "on" position, nothing has power. But when I press in the " ignition " button and have the key in the " on " position, everything receives power.
Even the hour meter advances, even though the motor is not running.
Is this correct ?
Is the " ignition " button supposed to act as main power supply along with the key ?
Even the radio only comes on when the key is in the " on " position and the " ignition " button is switched on.
Any insight would be much appreciated !
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2019 at 7:22am
Sounds right to me. That's the way it was built.
Here's the much used TRB diagram that shows the wiring going up to your key/dash. it doesn't show all the dash wiring inside the purple box that says "dash switched feed".
TRBenj is the guy who drew it up if you're brand spankin' new to the site
The 20 amp breaker takes away dash power along with ignition power and with the breaker ON and the key ON, the hour meter runs.
It's sensing power when the key is in the ON position it's not smart enough to know if the engine is running or not
The 20 amp breaker is labeled and called the "ignition breaker" but it really takes away all the dash power too.
You don't have an "accessory" position on the key, so it has to be in the ON position for radio power and power to all the instrumentation
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2019 at 7:39am
And here in the link below is an 87 dash wiring diagram from the "miscellaneous files" section of the CCF reference section
It's not the clearest, easiest thing to read
KRoundy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2019 at 5:11pm
You're doing it backwards. I would hit the ignition switch and then turn on the key. Consider that ignition switch sort of like a battery switch in a newer boat. It provides the juice to everything and then you go from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay_L Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2019 at 6:15pm
Thanks for all the great info !! I feel better now.
I was a bit surprised to see that the key has to be " on " and the " ignition " button needed to be depressed in order to run the even the bilge pump and radio.
But if that's the way it was designed, I am ok with it !
My fear was that someone had rewired stuff. That is usually a bad sign. Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2019 at 6:26pm
I think you'll find that the bilge pump will run with the ignition breaker on and the key OFF.
It's from the dash hot feed , before the key switch. See the TRB diagram again right after the 20 amp breaker and before the key switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-18-2019 at 11:25pm
Thinking about it, I think you'll find that the blower, the bilge pump, the lights and the horn will all work with the ignition breaker ON but the key in OFF. Also if you have an accessory switch it gets power too.
With the ignition breaker ON and the key ON you then get power to the instruments and the ignition system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay_L Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2019 at 1:07am
I was out there tonight and what you said is correct !
Thanks again for helping put my mind at ease.
But I did notice something weird. If I have the " ignition " switched on, the oil PSI is maxed out. The needle shoots to the far right. But then when I turn the key on, it goes back to normal. ( at least, I think this was the sequence that caused the oil pressure to tac out )
When she is running, the PSI looks correct, which is what matters most.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-19-2019 at 8:36am
I'd check that sequence again.
And I'd suspect the wiring on the gauge being wrong
Could be just me but in boats I've had with that ignition breaker, I've always left it in the ON position since I didn't really see any need to kill dash power when it wasn't running
malones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malones Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 3:50pm
i just purchased a 1986 ski Nautique 2001, sometime when I press the ignition button it doesn't register, hence I cant start the boat. It's a hit or miss. Happened the other day when we were in the middle of the lake. Anyhow know where I can purchase a new button? any help would be much appreciated, thanks!
Malones
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 4:06pm
Click on the link below and you'd want the 20 amp one for the ignition Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 5:14pm
David,
Are you using the breaker/switch as an on/off on a regular basis? They are more breaker than switch and if used as a switch they tend to fail early. There's no need to turn the switch off every time you stop the engine like in the middle of the lake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 6:01pm
David,
You're gonna have to explain that "more breaker than switch" Pete
How's he gonna turn on the bilge pump, or nav lights or the blower for example?
They use the same combination breaker/switch with different amp ratings. No separate switch of any kind
But I do agree about the ignition breaker/switch not needing to be used  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 6:14pm
Those breaker / switches fail over time.  I changed them out for new ones and always kept a 20 amp spare in the glove box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 7:24pm
In the link below is an old thread  with a solution that  has worked some times for some people Wink
And here's a link to what you need on EBAY for a bit less money.  Quite a bit less  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2021 at 9:38pm
Can’t hurt to give the WD-40 “fix” a try…
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: September-28-2021 at 8:35am
I bought a new one to put in but hitting it with WD40 4 year ago and using the boat regularly has kept the new one a spare part.
