  New Posts New Posts RSS Feed - Swim platform
Swim platform
Stuckers Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Swim platform
    Posted: November-02-2019 at 10:33pm
I have a swim platform I have cleaned it the way it suppose to and then when I put the teak oil on then it drys up and leaves white spots on the wood. What would be causing this to happen. I have put 2 caots of oil on the wood.
Mille1sj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mille1sj Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2019 at 1:04pm
Post a few pictures of it. How old is it? What product did you use to clean it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2019 at 1:10pm
Teak oil and teak cleaner and brighter won’t let me post pictures
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-05-2019 at 5:17pm
I use the teak oil and Teak cleaner and brightener
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mille1sj Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 8:27am
I can see around the edges where it looks like you go a better finish, I would go back over it again with the cleaner and use a scrub pad or one of the star brite teak scrubs to remove any discoloration. also make sure when you wash it with fresh water to remove any cleaner before applying brightener or teak oil. If you still have discoloration after that, you may need to lightly sand the entire platform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 8:31am
Mike,
It looks like you didn't let the wood dry enough. It may take several days depending on the conditions. IE: out in the sun or not.
Mpost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 8:37am
What did you use around the edges that are a lighter color? Pressure washer? the white reminds me of my wood deck when I have tried to use a cleaner/brightener. Its like is bleaches the tiny pieces of wood white and has to be removed. Me thinks it needs more sanding or scrubbing as mentioned before prior to the teak oil.
84 SN Sold   98 SN    Lund Pro V   1975 Alumacraft
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 9:03am
I was thinking similar, likely the water-based steps raised the fibers and created bleached filaments that need to get knocked off with a light sand after its dried, before the oil step
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 9:05am
Thanks everyone and I did let it sit out in the sun after I cleaned it for about a week when it was 80° Or higher outside. I will try to go back and maybe sand it down again.
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 1:41pm
Board is not clean enough.... power wash it + light sand or steel wool+ lots of oil= perfect
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 3:38pm
Don't sand it smooth or you'll have a very slippery swim platform.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mpost Quote  Post ReplyReply Direct Link To This Post Posted: November-06-2019 at 6:51pm
+1 on that.
I didn't even sand mine. Brushed it well to get it clean but kept applying Teak oil till it would not absorb anymore last winter. Tooooo much, Very slippery this summer, but hell, it looked great..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2019 at 9:17am
Thanks everyone. I am going to do a light sanding and then power wash it.
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: November-08-2019 at 7:01pm
Kind of changing the subject but still talking about swim platforms. I just wrapped my wife's birthday present on the swim platform in the garage because I knew that I wouldn't get caught. Platform has many uses in these parts.
I used to hang ten - now I hang six . And another thing - "GET OFF MY LAWN.".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2019 at 6:37am
Is there a certain steel wool pad I should use. Or will any steel wool pad work
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-09-2019 at 7:00am
Steel wool should never be used on wood. Small pieces of steel will break off, get stuck in the pores and then rust. Ether bronze wool of a non metallic like "Scotch-brite) should be used.
Otto Throttle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Otto Throttle Quote  Post ReplyReply Direct Link To This Post Posted: November-12-2019 at 10:03pm
Sand, blow off with compressed air, and a couple of coats of Sikkens. Did it 3 years ago and still looks new. NOT slippery....
I have 3 great photos but the system will not let me post them
Otto
Copyright 2019 | Bagley Productions, LLC
