1956 Carburetor (Graymarine 70) |
56-Atom
Groupie Joined: September-30-2018 Location: Dayton, OH Status: Offline Points: 78 |
Posted: December-15-2019 at 12:26pm |
The carburetor for my 1956 Atom is removed for winter clean-up. I have the original maintenance manual, helpful for me to learn the parts and functions etc. Regarding carb maintenance the manual recommends sending for "Graymarine Service Bulletin No. 533 (no charge)" I don't have and google search did not locate this info.
Suggestions and recommendations for a 1956 Graymarine 70 carb overhaul? This is for general clean-up and replacement of gaskets as the engine performed well this past summer. |
56-Atom
https://www.facebook.com/media/set/edit/a.1729455880510267/ |
John,
Call Jim at Fine Wood Boats for a rebuild kit. He will need the carb number that's on the small round brass disc attached to it. I highly doubt you will need the service bulletin since the carb is probably the simplest out there to rebuild. . As you see on Jim's site, he is moving and will be my new neighbor. I just made a dump run and stopped at his house on my way back to see if he was around. Not yet as I'm sure he's still very busy with the move. I believe he told me he has like 70 engines to move and then there's all the "smaller" stuff ! |
56-Atom
Thanks Pete! |
56-Atom
