Motor advice needed |
brantb
Groupie Joined: May-15-2019 Location: Colorado Status: Offline Points: 94 |
Posted: December-23-2019 at 11:57am |
It is finally cold enough in the garage and i have some time so i have started working on the boat. I am doing motor work now(thread coming soon), and am ordering parts. I have some GT40P heads, ordering a weiand stealth intake, 4160 rebuild kit, gaskets and head bolts and other misc items
Just wondering if the DUI distributor/wires are worth the ~$500. What about a new cam. Not sure i want to tear into the motor more, but it is also out. Figure $250 for a new cam and lifters, could probably reuse the push rods. Also, how do you break in a cam and set the timing? Seems like it would be hard to run it at ~2500 rpms and varying the rpms and get the timing set. Do you just set it close enough, break in the cam, then set it to whatever it is supposed to be? Anything else i need to order? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10652 |
As far as the cam goes, you could talk to the outfit in the link below about a cam and their break in service for an extra 60 bucks, then you won't have to worry at all about the break in procedure.
link They may be pretty close to you too depending on where you are in Colorado |
Nautiquehunter
I have been using the automotive HEI distributors found on eBay seller theswapmeetparts (24237 . You will have to remove the vacuum advance, install a vent and re curve the advance weights but for $99.00 with wires its well worth it . You will also have to remove the pin on the cam gear and let it float. I have been running them for years on three different boats. They work perfectly. Let me know if you need more information Mike 678-227-8833
You could at least give him a link to your thread about the "conversion" Here's a quote from a different thread from 4 days ago and the link is in there
You'll probably notice that I just threw out some information so he could decide in his own mind, just like you did whether you feel safe with it. I'll leave it to others to discuss whether it's safe or unsafe to them. Just call me "undecided" I'm sure there are plenty of people out there just throwing in the automotive distributor with no modification at all in their normal rotation engine. it's a little tougher in a reverse rotation Ford though. |
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3327 |
Consider if you clock the lifers and rotate the engine 20 revolutions before putting on the intake, you can verify all the lifters are rotating, or not.. Then with more certainty the cam will survive break in, or correct the issue immediately before damage occurs. at startup
I'm partial to a pertronix igniter triggering an MSD box and blaster 3 coil I take your engine is std rotation? That cam seems a good improvement without being too much , i'm running similar lift at 214/224 duration However you should do some thought about running roller cam valve springs with the flat tappet cam. that said many have done it successfully without issue. You may want to measure some spring pressures and make sure its not too high, and of course oil additive. |
