  New Posts New Posts RSS Feed - coil and points
coil and points
Ryjamsan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryjamsan Quote  Post ReplyReply Direct Link To This Post Topic: coil and points
    Posted: January-14-2020 at 8:40pm
Hello Gents
I purchased a complete HEI dist coil wires cap kit for a 75 Ford 302
The Gear turned the wrong way and would no fit
I decided I could just swap out the gear from my old corroded dist. Nope The old gear has a shaft ID of .457, the new Dist has a shaft ID of .497 so no luck
WTH so its on the way back to the seller
This 302 spins clockwise as it should. Why would the gear be backwards( the dist turns counterclockwise as it should.
Anyway I found an original 302 Dist online in working order with new points condenser and very clean
Comes in sat
So the question is what kind of Coil do I need?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryjamsan Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2020 at 8:51pm
also point gap should be 17 and dwell between 25 to 30?
This should right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2020 at 9:13pm
James,
Your old RR gear needs to be bored out to fit the new HEI. There are a couple threads on it here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryjamsan Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2020 at 9:25pm
my local machine shop cant bore it. that was my fist thought and course of action
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 8:04am
Why not??????
Also are you purchasing "MARINE" units??
        1978 Mustang (modified)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 8:09am
[QUOTE=Ryjamsan]This 302 spins clockwise as it should. Why would the gear be backwards( the dist turns counterclockwise as it should./QUOTE]
Which end of the engine are you viewing from???
If looking from the front to the transom as you should, then it should spin CCW. Both distributors will spin CCW looking down from the top when installed.
What boat do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 8:40am
Uh Duane, you're gonna confuse people, I think all the smoke from those 70 birthday candles the other day affected you.
Your way is bass ackwards, although it makes sense for a car application
In the marine world, you look from the back of the engine at the flywheel to determine rotation and a reverse rotating engine would be Clockwise
Reverse rotation = Clockwise = Backwards sometimes spelled as Backerds on CCF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 10:46am
KenO. Is my glass half empty or half full?   Ur right. Still can’t figure out why his shop can’t bore a hole. I should grind up a reamer and rent it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryjamsan Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 1:37pm
Cant make a shop ream it if they say they cant
His reasoning is that its hardened and tempered steel
I guess we don't have as good of machine shops as you do up north
ITs a mute point now I returned the part and bought a used refurbished Dist from a guy who had a 30 marine engine. It has points but its better than nothing
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 1:57pm
Nothing wrong with points other than having to do routine maintenance. It is not a bad idea to check under the dizzy cap once a year anyway, if nothing else to oil the weights.
An argument can be made that EI gives better fuel economy, maybe true but doubt you could measure it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 4:21pm
Like you said, it hardly matters now but your old gear from a 75 RR 302 would have been some pretty easy drilling/honing cast iron
This should right?
Not knowing what brand your distributor is, those are pretty good generic numbers, keeping in mind that if you change the gap the dwell changes and if you change the dwell the gap changes
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2020 at 9:43pm
I agree.
I sure hope your mechanic is better working on engines than he is with machining metal. The bore of the gear is not hard like he thinks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2020 at 8:07am
Pete, Please don't be spreading that around cause you are going to make me have to warranty all the gears I have done for CCF on here!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2020 at 9:03am
Duane,
I don't feel you have anything to worry about since without any doubt, the re bores you made were perfect.
Too bad James didn't come here first and get better info before he returned the HEI.
Nautiquehunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:26am
To increase dwell you have to decrease the point gap and vice versa . Always set the dwell then the ignition timing . Changing dwell also changes timing.
Copyright 2020 | Bagley Productions, LLC
