  New Posts New Posts RSS Feed - Need quick help on winterizing my new purchase.
 Post Reply Post Reply Page    <1 234
Post Options Post Options   Thanks (1) Thanks(1)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2020 at 2:41pm
That is a typical surge brake, I have the same unit on my car trailer. They work great when they work.
When these are working you hit the brakes in your car or truck and just after that you feel the boat brakes start working and you can ease off your car brakes a little as you manage your stop.
After the stop when you take off you will feel a slight tug as the boat brakes are still applied.
When your tow vehicle starts to move it will release the trailer brake. If you are paying attention you will feel this slight tug as the tow car first starts to move, very slight but you know you just released the trailer brake.
When they are not working you will hear more than feel the surge brake on the trailer apply as you brake but you don't feel the trailer brakes kick in to slow you down.
They work very well normally but take a little maintenance every year to make sure you are good to go.   Check the fluid, I use 100% Dot 5 because it will not remove your trailer paint when it spills. Dot 3,4, and 5.1 will all remove paint at first touch.
To run the Dot 5 your system must be flushed because Dot 5 is not compatible with any of the other brake fluids.
Rust in your trailer brakes, Low fluid or a leaking wheel cylinder can stop these from working.   They also get out of adjustment as the brake pads wear and they do not auto adjust so you need to go under the trailer about once a year and give the brake a quick adjustment.
I check mine every year before the season to make sure they are working.
I know other guys who have had their boats 10 years and not ever touched the brakes?
In my opinion they have no idea if those brakes work proper or not at this point.
Your boat and truck look great. Should give you years of fun with the family.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2020 at 2:41pm
Chris - I have the same setup on my Shamrocks trailer pretty much the old standard. Without a reverse lockout I’m guessing you have drum brakes on it. Probably needs some attention. Once the boats off you could jack the trailer up and with a helper at least see if they are working. You can place a big screwdriver in the front of that master cylinder and push back on that rod that has the two nuts on it - that is the master cylinders push rod. There are rollers under that tin cover as well that could need lubricant.
They won’t work as nice as the new disc brake setups but should do the job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2020 at 3:22pm
Don good to see your still working- with the economy booming I’ll bet there is less competition especially with both daughters in school it has to help the cash flow. Wait til you marry them off . Do they still do the shotgun thing way down south there? Where do your parents live on the weekends when they are not an hour north?
Gary,
Yes, the ladies still love a full figured guy. Those Mary Kay Conventions get real crazy when the ladies are away from home.
My sister does three days each week during the week and I do the weekends. I have a lady that comes in each morning and another one that comes into their home the evenings when we are not there. My dad just spent six days in the hospital and the last seven days at a rehab facility. He will be released next Tuesday, we hope. He (83) and my mother (84) are on that down hill slide. Work is crazy and I travel 13 states with work. Never a dull moment. I put 25 hours on the boat last summer when i normally get 60. This summer is looking bad for boat time.
When i get through this, I will then have the in-laws to deal with. They are younger than my parents. Then it is my turn to put the diaper on.
Donald
1968 Ski Nautique, Project.
C_Heath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2020 at 4:50pm
Thanks! I dont feel the trailer pulling me back at all. When I get on the brakes hard, my pedal just goes further than it does without the boat. May have to do some investigating. The brakes are dis
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold)
2000 Pro Air Nautique/GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2020 at 4:53pm
These are discs. Its pouring snow. Ill check all these tips out. I dont feel the trailer tugging me back and I get into the brakes pretty hard. Thanks alot.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-20-2020 at 5:45pm
Chris,
I can't tell from the pictures but does the trailer have a fold away or removable tongue? If so is there a quick connect fitting in the hydraulic brake line that may be disconnected?
Post Options Post Options   Thanks (1) Thanks(1)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2020 at 12:27am
Disc brakes are a nice upgrade, I wish I had them. It does sound like they are not working but an inspection will let you know. Not hard to fix and not too expensive either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2020 at 3:52pm
Chris,
I dont think but will make sure. It snowed yesterday. We never have snow unless I buy a boat lol.
Thanks!!!!
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2020 at 4:16pm
Chris,
doesn’t appear to, looks like the A Frame is tied together right behind the actuator.
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2020 at 5:12pm
Here is how to manually work the master cylinder with a screwdriver when you finally get a chance. If you have a strong enough jack lift one wheel up have someone spin it and depress the master cylinder. That will at least give you an idea whats going on.
Post Options Post Options   Thanks (1) Thanks(1)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2020 at 5:20pm
Or remove your ball mount from the receiver and insert in actuator. That trick works well for bleeding the brakes also.
Post Options Post Options   Thanks (1) Thanks(1)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2020 at 3:53pm
There was mention of a reverse lockout for the Titan coupler.
To get a trailer into my backyard where my garage is I need to back the trailer through a 90 degree turn that has an uphill grade. Surge brake connectors like this titan or the atwood apply full brakes when I try to put a trailer away. Even with 4wd and large tires in low range this is a hard maneuver and impossible if those brakes apply and are fighting me.
On both my Atwood on the boat and my Titan on the car trailer I measured and drilled a hole right behind the slider in the titan and behind the swivel in the atwood.   The hole goes all the way through both sides but did not touch any of the parts inside.
( The Atwood has the sliding lockout built into it but the dang thing would not hold and self released trying to put the boat into my yard, so I drilled it and use my bolt lock. )
In each case I can slide a 7" bolt through the hole and lock out the brakes. It has worked for me for over 20 years.   A simple electric line block would be easier but the bolt has worked well for me and allows backing up the trailers uphill and around the 90 degree turn.
