  New Posts New Posts RSS Feed - 14x14x16 1 1/8 3 blade RH prop
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Topic: 14x14x16 1 1/8 3 blade RH prop
    Posted: February-27-2020 at 6:48pm
14x14x16 1 1/8 shaft RH prop 3 blade OJ or federal just refreshed 150. venmo and zelle accepted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2020 at 7:26pm
Darn, I need a 14x14x16x16. So close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2020 at 7:37pm
Roscoe
With all those numbers that's gotta be ultra super duper high performance.
Maybe it's one of them there fancy duo prop setups
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2020 at 8:14pm
Roscoe
I needed a HP calculator to figure out all the stampings
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2020 at 9:11pm
But you don't know what you have there.
Through the magic of the internet, I see your prop pictures someplace else with all kinds of funky markings.
I figure it got repitched and restamped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: February-27-2020 at 9:51pm
it was NOT repitched. they stamp their own numbers on it for reference when they balance it for whatever reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 7:41am
So it must have some kind of identity crisis.
It doesn't know if it's a 14 X14 prop or a 14 X16 prop
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 9:02am
Can the 16 pitch be measured accurate
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 9:58am
Time for a little snarkasm Daryn
No it's impossible and it's just an arbitrary number that gets dreamed up .
But anyways It's not the most straightforward thing to do.
Google is your friend.
PS .....................Cheese on the burger would be good
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 11:16am
Of course, cheese and snarkasim go well together
It is just a big screw (threads per inch or inches per one thread)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 11:27am
The pitch is the theoretical distance the prop (boat) will travel forward or reverse without any inefficacy due to slippage.
Pitch blocks are wedges typically wood that are placed next to the prop blade to check the angle. They are specific to the pitch/angle and are what prop shops use when rebuilding or changing the pitch of a prop. Now the more sophisticated method of measuring is laser scanning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 3:43pm
Good thanks for explaining
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2020 at 9:39pm
I seen a listing for a 14x14x16 for sale in Orlando. Lots of metal missing on it. When all the metal was there It might’ve been a solid 14x14x16x16. Maybe even a 14x14x16x16x18.
Or was it a 14x16 and they took metal off to make it a 14x16?
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2020 at 12:41pm
Wow that’s a crazy prop
According to google that prop will move you 64” every rotation
At 3500 rpm your boat should be going 212 mph
Y’all are fast in Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2020 at 2:51pm
This is the correct information
14 RH 16 Cupped 1.125" Bore.
OJ Propellers 1052 Legend 3-Blade Ski Boat Propellers.
The name speaks for itself. The OJ Propellers Legend is exactly that- something incredible handed down form one generation to the next.
What began as Oscar Johnson's dream, OJ Propellers has been redefined and perfected until it has emerged as the professional's choice in original tournament boat equipment.
